Old 07-26-2012, 07:19 AM   #1
oc-boxster's Avatar
question about which suspension
I was trying to order some suspension parts for my 2002 S model and noticed there are some options, standard, M030, ROW..whats the difference, and how can i identify what my car is set up with? I have the original window sticker from the car but it gives no specific info, it does have the sport touring package as a 3400.00 option if that makes any difference.
oc-boxster is offline   Reply With Quote
Old 07-26-2012, 09:33 AM   #2
l3m
l3m's Avatar
I believe the 'Special Chassis Rigidly Tuned' option is the M030. You can verify this by looking at the option codes label on the underside of the hood. There should be an '030' code listed. If you don't have that code, then you have the standard 'S' suspension.
'01 S
l3m is offline   Reply With Quote
Old 07-26-2012, 10:49 AM   #3
oc-boxster's Avatar
Ok thanks for the info..I do not have an 030 code listed
