Old 04-10-2011, 07:51 AM   #1
Suggestive Maintenence Advice Please?
Guys, I've had my car now for over three + years now. Mileage as of a run last night is almost 21k.
When I purchased with 13.5k miles, Jim Ellis Porsche in Atlanta completed the 15k service.
Since, I have had one oil change and general springtime service @ JPA Nashville two years ago other than having my mods in sig installed by both JPA and a local indy shop (highly recomended) in the Nashville area.
I'd like some advice on what I should do at this time, if anything??? The car drives and handles flawless. No oil spotting on the garage floor from a bad rms and no crazy hesitation problems or smoke from an old maf.
Basically she shows and drives like new other than some typical rock chips on the front bumper and bonnet.
Any ideas for maintenance this spring or do you think I'm good for another year? Thanks for your input! Just want to take good care of her.
Thanks, Jon
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
jwade is offline   Reply With Quote
Old 04-10-2011, 08:29 AM   #2
boxster6354's Avatar
I change my oil each year regardless of mileage, cheap insurance and piece of mind.
Old 04-10-2011, 08:43 AM   #3
Jager's Avatar
As boxster 6354 noted below, it is important to change the oil regularly. I change my oil every 3500 to 4000 miles. I believe it is also important to get the motor up to temp after you start it, this ensures that all the water moisture is evaporated from the oil after a cold start... I have over 209,000 miles on my 01.
Jager
Old 04-10-2011, 10:25 AM   #4
Gforrest2's Avatar
209,000? Wow. So no IMS replacement? How many water pumps have you changed out? Maybe there's some hope for me as I just turned over 83k.
Glen
Old 04-10-2011, 11:36 AM   #5
Had the last oil change @ 18000+ miles two years ago. Had my indy mechanic look at it last summer when I had the RoW setup and headers installed. He said it was fine.
Just wondered if necessary this year or if maybe something else should be looked at? Thanks for the comments.
Old 04-10-2011, 12:19 PM   #6
JTP
Even though your oil may look fine, there's no way to tell how much acid has built up in the oil without having it analyzed. General consensus is to have the oil changed atleast once per year if you drive less than 5000 miles. I change mine out every 4-5000 miles.
JTP is offline   Reply With Quote
Old 04-10-2011, 01:12 PM   #7
Originally Posted by jwade
Had the last oil change @ 18000+ miles two years ago. Had my indy mechanic look at it last summer when I had the RoW setup and headers installed. He said it was fine.................
Good grief; along with an oil change, you need to change mechanics…………..
Old 04-10-2011, 02:16 PM   #8
Jager's Avatar
No IMS bearing replacement but someone on this site has rattled my cage enough that I will be replacing the IMS bearing in a couple weeks (I have a small oil leak, need to investigate). While I'm in there I am going to replace the RMS, flywheel, and clutch.
I replaced the water pump when the car had ~204,000 miles on it, not too long ago.
My 986 is the best car I have ever owned, it's the only car I've owned that has not left me stranded. I've been racking-up all these miles and not putting any money into it... I need to take care of it.
Jager
Old 04-10-2011, 04:44 PM   #9
Your car is 10 years old
and fluids, belts, tires, plastics all degrade with time as well as mileage.
I bought my "01 at ~42K miles and promptly did a 60k major service along with things it needed like brakes just to get a handle on where the maintenance was. Very reliable since over ~5 years so this year it is due for a 90K service at 58k just because I again want to establish a maintenance point.
Old 04-11-2011, 08:46 AM   #10
Jager
Let us know what the IMS bearing looks like on a 209,000 miles vehicle, please.
thanks
lifeisgood is offline   Reply With Quote
Old 04-11-2011, 11:53 AM   #11
Wait a minute? There's a fear monger lurking around here someplace? I don't believe you. Where?
Congrats on the 209k
As for the OPs request for SUGGESTIVE maintenance... sorry, all I could find was some related to BMW but here you go (they're not that hot either but trying to help out):
sub5zero.com/girls/hot-girls-power-tools-working-bmw-rally-car
Old 04-10-2011, 05:54 PM   #12
jdiba's Avatar
Thumbs up Jager
"I have over 209,000 miles on my 01."
Original motor Jager ?!? If so, unfrickin believable.
jdiba is offline   Reply With Quote
Old 04-11-2011, 05:19 PM   #13
Jager's Avatar
Yes, original motor. The only work done on the car are brakes, windshield replacement, a new top, water pump replacement, AOS replacement, a couple sets of plugs, a couple new belts, lots of oil/filter changes, fuel filter changes, and many sets of tires!
Old 04-13-2011, 05:56 PM   #14
Jager's Avatar
Yep, over 209,000 miles!
