Old 04-08-2011, 02:36 PM   #1
rear wheel bearing
I went to replace the rear brakes on my 01 Boxster S and jacked up the drivers side and behold some play with the wheel on. So I have to replace the rear wheel bearing. Is this a big job? Should I replace the other side as well. Car has 100,000 miles on it. Is this a common wear item on older Boxster's? Ahh the fun of spring car maintenance.
2011 Cayenne S
2001 Boxster S
teamwenz is offline   Reply With Quote
Old 04-08-2011, 05:28 PM   #2
I've got (I believe) a similar issue with a front bearing. From what I've read, it's not too terribly bad IF you have the right tools (ie, the SIR wheel bearing kit), which are a bit pricey. Getting the axle nut off I guess is a challenge as well---it's supposed to be torqued to something over 300 ft-lb, IIRC.
You'll get more complete answers from those who've done it, most likely. Also, check out:
http://www.pelicanparts.com/techarticles/Boxster_Tech/40-TRANS-Wheel_Bearings/40-TRANS-Wheel_Bearings.htm
Old 04-08-2011, 05:51 PM   #3
Topless's Avatar
I just had all four wheel bearings done. I lack the tools and the inclination to DIY. $1200
Old 04-08-2011, 06:10 PM   #4
That was done by an indy I assume? I had the stealership quote me somewhere around $1000 just for the one front bearing
Old 04-08-2011, 06:49 PM   #5
Topless's Avatar
Yep, the same shop that does all my suspension setup work. They already had it on the rack so it was a "while you are in there" deal. One bearing had noticeable slop and two were getting noisy.
The bearings are only about $60 ea. Figure about 2-3 hours per wheel.
Old 04-08-2011, 09:14 PM   #6
Thanks for the replies, I will let you know how it turns out. The brake job I could handle no problem but I am letting a local shop (Accumoto) tackle this one. There was no warning or signs until I jacked up the wheel and took the load off it. It seemed fine last year and I just took the car out of storage. It was explained to me that moisture can get in there and do some damage over a winter storage period.
2011 Cayenne S
2001 Boxster S
