Old 03-30-2011, 06:20 PM   #1
jaykay's Avatar
amberectomy - pliers only
Have any accomplished an amberectomy without the use of a soldering iron. I recall coming across someone who said they did it better with just pliers.
I suppose if the the lense has exposed edges this might be possible....
Any pointers on the process with or without the iron would be appreciated as a source for the proper silver coated amber bulbs...for the sides as well
986 00S
Old 03-30-2011, 09:54 PM   #2
http://www.xenonmods.com/
Old 03-31-2011, 05:18 AM   #3
ddb
www.klisstle.com
ddb's Avatar
I remember reading somewhere about performing the procedure with only pliers as well. I decided to do the procedure on my new, out-of-the-box Litronics about 6 years ago before installing them onto the car. I thought with a little patience and multiple lengths and shaped pliers I could remove the amber without heat. Evidently I wasn't patient enough. I don't remember how long I tried, but I eventually had to buy a soldering iron to get it done. Others have done it without heat, so I'm sure you can too. Sorry I couldn't offer something more positive.
Best of luck,
ddb
Old 03-31-2011, 05:49 AM   #4
I used an old soldering iron I had kept and a pair of very long needle nose pliers...didn't take very long, but the hot iron makes very quick work of the amber plastic, making it quite simple to pull out with the pliers. The amber plastic is quite tenacious and you risk damaging the headlamp by attacking it with pliers alone.
Purchased the silver/amber bulbs from a eBay seller...very nice quality.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 03-31-2011, 03:25 PM   #5
I too used a soldering iron on my brand new clear headlights... Can tell you I was nervous as hell, but it really was a very easy job with the soldering iron.
Sam
sparker is offline   Reply With Quote
Old 04-01-2011, 07:58 AM   #6
jaykay's Avatar
Okay thanks guys...I will have to get hold of a thin soldering iron to break up the lenses. I was concerned with the hot plastic falling free on the inside and fusing to the inside of the housing...how is this avoided?
986 00S
Old 04-01-2011, 04:11 PM   #7
your best bet is to use the soldering iron. those plastic pieces are very flexible and you'll end up scratching the plastic lenses around it.. so use the iron to melt pieces away and a pair of super long noses to pull em out...
mikes_box is offline   Reply With Quote
Old 04-01-2011, 05:07 PM   #8
For those that don't have the links.....
Pics of the process: http://hverheyen.vssi-eda.com/box_pics/lights/index.html
Instructions: http://hverheyen.vssi-eda.com/box_pics/lights/instruct.html
98 Arena Red 986
Stroked & Blown is online now   Reply With Quote
Old 04-03-2011, 08:06 PM   #9
jaykay's Avatar
Okay so both tools at once as in grab hold and then melt so nothing gets dropped ?
986 00S
