03-30-2011, 10:54 AM
Question on checking oil and adding in 05 S
Don't have the manual on me right now but have a question. When I go to start my 05 S I turn the key a bit and wait for it to cycle and check the oil level. It checks and shows lower than normal range. Do the lines represent a quart, 1/2 a quart, etc? I am guessing I need to add it to it because I let it cycle when warmed up and cold and it still shows being low.
Thanks.
02 Boxster S (sold), 05 Boxster S (sold), 00 Ferrari 360 (sold), 05 Boxster S (sold), 01 Boxster S (sold), 99 Boxster (sold)
03-31-2011, 05:42 AM
Each line represents far less than 1 quart or even 1/2 quart. I never have to add oil to my 987S between changes, but IIRC from the Owner's Manual, each bar is about 200-300ml.
And, you are doing the right and correct procedure to check the oil prior to each cold start. Good job! Takes less than 30 seconds. Very accurate.
Fill the oil to one bar BELOW the top range. Add about 200-300ml's prior to each cold start the next few days, until you get up to that mark. Take your time, be patient. Easy.
04-04-2011, 08:56 AM
I've added a quart over the past day and it still shows low on the indicator. Oil was just changed before I bought the car from a non Porsche dealer.
Do I really keep adding oil? I will check level again this evening when the car is totally cold.
04-04-2011, 09:06 AM
make sure you're checking on a level surface. if you're on a hill or tilted sideways you'll get an erroneous reading
04-04-2011, 01:01 PM
Has it ever read full during your ownership? During the addition of the quart you added, did any of the bars move up? Can you post a picture of your gauge? Are you adding the oil to the correct opening in the frunk? Black cap with the pop-up funnel.
Don't add any more oil until this is figured out. You may be over-filled now with an inaccurate gauge.
04-04-2011, 02:29 PM
Don't think the orafice is in the frunk.
1989 928 S4 5 spd - black
04-04-2011, 03:22 PM
oil + brake fluid = no good!
remember, always oil in the rear...
04-20-2011, 03:40 PM
My guess is they put in the regular 5 litres and not the amount these beasts take.
04-20-2011, 04:10 PM
That's my guess too. People never believed me when I told them the diesel engines in my boat took 15 quarts each. Always best to check the manual.
Can't wait for the weather to change and use this as my daily driver!
