Old 03-15-2011, 08:44 AM   #1
OK to lube wheel bolt cones?
Recently I had to unbolt some wheels on my 2000 S and I had a tough time. I don't think the actual torque was excessive but there seemed to be a lot of friction at the spinning cone part of the bolt. I couldn't really tell if was the cone-to-wheel contact or the cone-to-bolt head. I want to lube this area on all the wheel bolts but I thought I better check first. Somewhere I remember reading that antiseize on wheel bolt threads was wrong and that they are supposed to be dry. What about the cone area?
Dale_K is offline   Reply With Quote
Old 03-15-2011, 10:32 AM   #2
BYprodriver's Avatar
Porsche says do not lube "cone" to wheel contact area. I believe the purpose of the cone is to reduce friction between the lug bolt & wheel surface. I use a thin coat of anti-sieze on all lug bolts/studs & if I had the problem you do I would lube under the bolt head also. Basically you want the "cone" to not move & the bolt to be low friction for a true torque reading. I drop my install torque to 90 ft.lbs. due to the reduced friction.
Old 03-15-2011, 12:29 PM   #3
I use a few drops of oil on lug nuts/bolts, it doesn't change the friction and resulting torque as much. Nothing between the cone and wheel.
