Old 03-06-2011, 07:25 PM   #1
dim headlights
1999 boxster with 35k mi. suddenly has no headlights either high or low,though tail lights are on and brake/backups work. just has the dim "city lights" in front. using the passing flasher the high beams can be made to work. no lows though. any ideas ?
strokersquid is offline   Reply With Quote
Old 03-06-2011, 09:34 PM   #2
have you taken the headlights out recently? (might indicate putting them back in incorrectly)
how's your ignition switch? hard to get the key out?
fuses ok? connections inside the housing ok?
stateofidleness is offline   Reply With Quote
Old 03-08-2011, 10:00 AM   #3
haven't touched them since purchase. i suppose they could both be burned out but why wouldn't high beams work ? No, the ignition is fine. Can't find any blown fuses
Old 03-08-2011, 04:02 PM   #4
gregdacat's Avatar
Could be the headlight switch. I had to replace mine last year. Did the same thing. Everything worked but headlights.
Greg
2002 Triple Black, Desnorkled, Bumper Plugs, LN IMSB Upgrade
gregdacat is offline   Reply With Quote
Old 02-08-2012, 08:50 AM   #5
Take out your headlight switch, spray electrical cleaner into every holes you can see, shake it for a couple minutes. Repeat this a couple times, then let it dry for a day or so. Reinstall it. It works for me. $6 dollars fix or you can spend $130 for a new headlight switch.
kevinle92618 is offline   Reply With Quote
