Old 02-18-2011, 11:17 AM   #1
Removing front headligts help!
Trying to help a buddy remove the front headlights on his 98 boxster but he smartly lost the headlight tool. Since I no longer have a porsche I don't have the tool either. Is there something that we can buy locally at home depot to use to remove it. I don't remember it being anything special..
mikes_box is offline   Reply With Quote
Old 02-18-2011, 11:55 AM   #2
Jaak's Avatar
From one of my previous posts ....
Insert 5 mm Allen key into the opening and rotate the key 180 degress to the front of the car. Key starts with the handle facing the rear of the car. The headlight pod will move forward. Rotate the key 90 degrees to the rear.
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
Old 02-18-2011, 11:56 AM   #3
You don't need the "special tool"...a hex socket (I don't recall the mm size) and an extension is all you need to turn the lock in the frunk.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 02-18-2011, 11:57 AM   #4
Maybe try this
go to a local wrecker that has boxsters
offer to buy tool kit for a couple of bucks
Chris
Living one calculated risk @ a time
chris97boxster is offline   Reply With Quote
Old 02-18-2011, 12:05 PM   #5
it's a 5mm socket (not allen key). A handled nutdriver works perfectly too if you don't have a long socket extension to reach in there. Plus they are pretty cheap at parts/tool stores so pick one up and throw it in the spare tire's pouch for safe keeping.
Old 02-18-2011, 01:01 PM   #6
Thanks guys I knew you guys would know what to do!
Old 02-23-2011, 07:41 AM   #7
Jaak's Avatar
Talking
I've used a 5 mm Allen key (wrench) many times and my Indy P-car Shop does as well. Cheap device to keep in the car.
http://en.wikipedia.org/wiki/Hex_key
