Old 02-17-2011, 07:01 AM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
IPD Plenum kit on order!!
I ordered yesterday the complete plenum kit with the new cylicone tubing for 895 shipped to my door.
I think I have almost every bolt on part possible now other then a cold air intake. I do have the drop in BMC filter. I know the cold air system is not worth the money itself but with the plenum kit setup would it be a beneficial upgrade now?
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 02-17-2011, 08:20 AM   #2
Carnut
AndyA6's Avatar
That's great! Please do us a favor and report back with your impressions.
Also, did you include the larger throttle body? Where did you order from? Seems to be a good price!
TIA!
Andy
'14 Boxster
Old 02-17-2011, 08:22 AM   #3
Definitely let me know how this goes! We should try to get Ottawa Boxster guys together.
I contemplated this mod for my 3.4L but am happy with the current setup.
VRsyncro is offline   Reply With Quote
Old 02-17-2011, 08:59 AM   #4
2001 RUF 3800S
Yes I got the bigger throttle body 74mm separately. I ordered directly from IPD
I'll be sure to report back for you guys, but it will be installed when the salt goes away in spring.
VR - let's make it a point to organize a meet in Ottawa
IG: RUF3800S
Old 02-17-2011, 09:11 AM   #5
Johnny Danger's Avatar
As far as performance is concerned, there's no real net gain to be had by installing the cold air intake. However, at certain rpm's the sound is awesome . It has a real bark !
Old 02-17-2011, 02:36 PM   #6
2001 RUF 3800S
I'll wait for a deal. Even if it's a horse power or two, makes me feel better
IG: RUF3800S
Old 02-17-2011, 03:49 PM   #7
V&V Canadians, depending on how my house sale goes, I'd ride up to an Ottawa meet, especially if you can pointy out good places to stay where the parking is plentiful and safe.
eightsandaces is offline   Reply With Quote
Old 02-18-2011, 06:44 AM   #8
I installed the IPD plenum with the 74mm throttle body last fall and I highly recommend it...RPM climb smoother and faster and throttle response is better. Also, more sound is coming from the air intake.
John
CasualCarnivore is offline   Reply With Quote
Old 02-18-2011, 08:58 AM   #9
Carnut
AndyA6's Avatar
Good to hear! I'd like to do this mod soon
Viola, pm'd you!
'14 Boxster
Old 02-18-2011, 04:48 PM   #10
2001 RUF 3800S
Hey John do you have a cold air intake? If so was it installed before after the plenum? Also do you have the hose in your setup?
IG: RUF3800S
Old 02-19-2011, 04:13 AM   #11
Yes, I do have the hose as well. I have just a BMC filter which I installed the same time I installed full exhaust system back in May.
John
Old 02-19-2011, 01:19 PM   #12
2001 RUF 3800S
John,
I hear that the plenum setup is more rewarding than an exhaust system, is it true? What was a more noticable gain exhaust or plenum?
John
IG: RUF3800S
Old 02-20-2011, 05:36 AM   #13
John,
Here is my take on exhaust and plenum upgrades:
Exhaust setup gave the car more top end improvements in the RPM range where the IPD plenum kit seemed to improve the whole RPM range. I think both upgrades complement each other.
John
Old 06-23-2012, 10:58 AM   #14
fredpayne's Avatar
Did the 895.00 price include the plenum and throttle body?
2003 Boxster S - Orient Red
2010 Toyota RAV4
Past Toys
2000 Boxster - Ocean Blue
1994 Toyota Supra 320HP
1987 Porsche 944S
1983 Porsche 911 Carrera
1980 Porsche 911 SC
1976 Trans Am 455 Cu.In.
1962 Corvette Convertible
1957 Pontiac 2DR HT 421 Cu.In.
fredpayne is offline   Reply With Quote
Old 06-23-2012, 01:03 PM   #15
How does it compare with the Pedro techn o torque? at more then twice the price, is it worth it?
wawa
wawa is offline   Reply With Quote
Old 06-23-2012, 01:42 PM   #16
fredpayne's Avatar
I have no clue I haven't tried either one of them, however, after doing a lot of research, I don't think you need either one, the T shape of the factory plenum does it as well as anything since the air flow is not constant, without constant air flow the Y in the tube serves no useful purpose. The Boxster engine works and acts like 2 seperate connected 3 cylinder engines and I see no advantage to a 74mm throttle body or either plenum, IPD's or Pedro's. It would be like putting a 750 Holley double pumper on a 283 engine, not only an overkill but will reduce power, especially in this analogy since all you may need is a 500 Rochester or at most a 650 double pumper, I'm leaving mine as is, I figure the Porsche engineers are pretty smart. I have had my ECU flashed and have a Borla catback exhaust, that's about all I need.
wawa
2010 Toyota RAV4
Past Toys
1987 Porsche 944S
1980 Porsche 911 SC
Old 06-23-2012, 06:38 PM   #17
wawa
You might want to read this thread .
Pedros techno power2 kit vs ipd?
Old 03-13-2013, 12:39 PM   #18
Performance wise, the IPD Plenum coupled to a 997 75mm TB has bar none been the most rewarding modification to date! Please share with us your thoughts post installation.
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
Cartel is offline   Reply With Quote
