09-15-2010, 07:19 PM
#1
Interest in One-Touch Convertible button?
09-15-2010, 08:36 PM
#2
I bought a "homemade" relay that attaches to the factory switch (tucked away behind the trim bezel) years back from a forum seller. Works great to this day and I think I paid $60 or $75 for it. Funny part is, I still stop it to do the chop, so is it really worth it?
Added: It is nice for putting the top up...one touch and done, instead of holding button down.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
09-15-2010, 09:01 PM
#3
For those of us stuck doing the chop, which is the vast majority of 986 owners, one position wouldn't be of value. Now two position I might be interested in...
09-15-2010, 09:11 PM
#4
Thanks for the responses guys!
So to open the top you would want to press it once, have it stop half way, chop, press again for full tuck? And for putting it back up you would want a one touch?
How much would you pay for that?
09-16-2010, 04:40 AM
#5
Join this UK Boxster forum
and read this message on how to mod the relay yourself for full SmartTop functionality.
Link
09-16-2010, 10:52 AM
#6
I have the SmartTop and the one touch function is the ****************. The cool factor is the ability to drop or raise on the fly...up to 25 mph. Perfect for leaving a parking lot or pulling into parking and not having to sit there waiting for the top to finish doing it "thing".
09-16-2010, 11:08 AM
#7
I have the smarttop as well and don't know why that wasn't standard, although it's only half the convenience for people who need to do the chop thing.
The only caution to it is you don't want to have the top move up/down while you're driving over uneven surface (ie. bumps)... apparently it could break or damage the top mechanism.
09-16-2010, 12:32 PM
#8
Porscheectomy
It takes 12 seconds for the top to go up or down, I don't see the point. Convince me.
09-16-2010, 01:00 PM
#9
Thanks for the replies guys!! It's really helping the start up!
It's more of a personal thing. Some people are annoyed with having to sit there and wait the 12-16 seconds and not be able to do other set up procedures (iPod setup, A/C, seat-belt, etc.).
If it doesn't bother you to sit there and wait the 15 seconds with your arm stretched out and not being able to get the other pre-take off stuff done, then this product might not be of your interest.
09-16-2010, 01:09 PM
#10
Ditto!
Also a caveat. With the one-touch relays, if there is a problem with the top frame or such, you can easily bend frame members or the clamshell and do $eriou$ damage before you can stop the motor from running. This is one of the major reasons I have never been a fan of these.
Cheers!
09-16-2010, 01:20 PM
#11
Originally Posted by Lil bastard
Ditto!
Cheers!
With the smarttop if you press the button again it will stop it.
09-16-2010, 01:26 PM
#12
I've had the Smarttop for over a year now and love it. Bought mine used off eBay for less than 150. If you hunt online, you can get a good deal on one.
Just remember that when the window is cold, you have to chop it...I use a towel given to me by the original owner...But on a hot sunny day, once the window warms up, I do not hesitate to drop it without stopping to do the infamous "chop"...
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
09-16-2010, 01:32 PM
#13
I have a SmartTop
and use the "while moving slowly" feature all the time. Almost never use the one-touch as I need to do the chop due to the fitting of my top. I guess I use it when putting the top up on a hot day when it starts raining or just gets too hot and I pull up to a stop light and don't know how long the light is. Nice to be able to pull out and not hear the honking horns behind as the top closes the last 6 inches.
09-16-2010, 02:14 PM
#14
I would definitely use it... I have glass, so no need for the plastic chop, and while it's not a huge issue, it is an inconvenience to have to hold the button for the 12 or so seconds... Compared to all of the cool gadgetry in the more modern cars that I've been driving, such as the touch-open entry on the BMW and Lexus that doesn't require even using the remote fob or keys to unlock the doors (just unlocks or locks when you touch the handle, so long as your remote fob is in your pocket or vicinity), and push-botton ignition without having to reach for your keys, it makes small things like having to hold your arms stretched out and holding the convertible top button down for 12 seconds seem antiquated...
Please let me know if you are designing a cheaper alternative to the smarttop..
Thanks!
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
09-16-2010, 02:15 PM
#15
Okay,
The idea behind this is to do it on the run, that by the way is the only time you can use the one touch feature is to be moving at the time to active it-fwd or rev. If you’re stopped you have to hold the activation switch down (safety I guess). You also don't have to have the emergency brake engaged because it overrides this safety feature.
So let’s recap; No more E-brake, no more being stopped, no more holding down the button.
BTW, if you do have a bind in your top and you continue to activate the switch the first thing that will brake is the plastic socket of the ball & socket of the drive motor arm. It's made that way too protect the rest of the mechanism and they cost about a $50 for one arm...less at a salvage yard and easy to replace. I know because I’ve done it twice. Once because my wife didn’t unlock the top all the way and the second because neither did I.
09-16-2010, 02:52 PM
#16
Thanks a TON for the responses!
Thanks!
I love the way you phrased that. I will most certainly let you know if I start selling this product!
09-17-2010, 12:59 AM
#17
That's great news... Very much looking forward to this!
09-17-2010, 06:19 AM
#18
First, I'd be very cautious putting the top down when cold with a plastic window (can you say "crack"). Second, even when warm, the plastic window will crease at times if not chopped, giving you a nice pinch in the plastic. My top/window is 8 years old and in almost perfect condition, though this is not a daily driver.
The one touch is a nice convenience, if offered for a reasonable price.
JGM
2002 Boxster S
09-17-2010, 07:38 AM
#19
I've got the Bahntech Autotop. Half the price of the Smarttop. Works great - love it. Cost is $160 shipped, which I think is still a bit expensive. I think if a product like this could be $99 shipped, that you would sell a ton.
Demick
'04 Boxster S
09-17-2010, 08:40 PM
#20
Thanks for your response. Is there anything that you would change about that product?
