Old 02-04-2011, 12:59 AM   #1
tiptronic transmission shift normal when car is cold,when warmed up 3rd gear slipps
HI all,
i have a problem with my 99 boxster,it shifts normal when the car sits for a while and when i drive for about 5 kms and up the 3rd gear wont engage,it slipps
and again when it sits for a half hour it shifts normal
please advise if you have any suggestions
MumtazHallak is offline   Reply With Quote
Old 02-04-2011, 05:42 AM   #2
Sounds like
heat related and since the trans is cooled by the fluid inside and by a center radiator, I'd look at the fluid level.
Old 02-04-2011, 11:25 AM   #3
When did you last change the fluid and filter? Lifetime really isn't. Also if you have a Durametric you could check for fault codes in the trans. ED
cvhs18472 is offline   Reply With Quote
Old 02-04-2011, 04:16 PM   #4
jcb986's Avatar
I just did a TIP service on my 2000 S. Fluid was very dirty and I believe it was a good liter low, maybe more. Shifts a lot better now. The TIP electronic plug coming out of the trans has a connector to the harness...someone else had a problem and found dirt and grime had made a connection weak...cleaning solved his problem.
Old Hippie Young Heart
