Old 01-15-2011, 11:37 AM   #21
Originally Posted by baxster
I understand that Litronics has the leveling feature and projector lens. Other than that, is the light output (lumens) superior to a HID kit?
No but have you seen an incorrectly focused beam vs. a factory HID projector beam? You're likely to gamble on reliability (read: most kits are made in Korea/China) by going retrofit.
It's also harder to find 4300k HID kits as most of them tend to start at 6000k. The latter will make you go blind in rain or snow.
Old 01-15-2011, 11:51 AM   #22
CC no big deal!
I rarely ever use mine.
Norminhouston is offline   Reply With Quote
Old 01-15-2011, 01:24 PM   #23
Yes, incorrectly focused HID's are a pain. It's important to have a shield in front of the HID bulb that creates a cut-off beam pattern, and prevents direct glare from the bulb itself. From what I've seen, the 986's halogen lamps have such a shield. As long as there is a vertical adjustment, it might work good.
baxster is offline   Reply With Quote
Old 01-16-2011, 05:24 PM   #24
I got a 5 day take home test drive
In other words, I bought it! Carmax will refund after 5 days if I want.
Black was not my first choice due to the heat in cali and keeping it clean, but I've got to admit that black might be the best looking color for the box.
Now I have to get used to throwing around an extra 500 lbs. The box definitely feels heavier. Once moving, the steering feels much heavier, kind of like a manual steering rack without the extra road feel.
I'm going to give it a PPI in the next day or two. I've created my own list of things that need to be worked on so far, but at least there's no oil leak on the garage floor. The worst I've noticed so far is some surging on acceleration and mild engine tapping noise on a warm idle.
Otherwise, it's a great drive!
Old 01-16-2011, 06:53 PM   #25
Carnut
AndyA6's Avatar
Grats!!!!
You won't be disappointed, heavy does not mean in any way bad or anything, get used to it, in other words, drive it and you will def start to feel the good sides of this vehicle.
Pics??
Later,
Andy
'14 Boxster
Old 01-17-2011, 07:18 PM   #26
Congrats! And be sure to get that PPI immediately. CarMax is supposed to fix any problems you find within the first 30 days. That's how I got a new AOS and a new CD changer when I bought mine.
2002 Boxster S, 6 speed, Speed Yellow
Flat Six Innovations 3.8L Stage II Track Performer, RoW M030 Suspension, B&M Short Shift Kit, Fabspeed Bypass Pipes, FVD Brombacher "Sound Version" Muffler, UD Pulley, Low Temp T-Stat.
Banana S is offline   Reply With Quote
