-   -   water pump (http://986forum.com/forums/boxster-general-discussions/27183-water-pump.html)
jaykay 12-16-2010 04:43 PM
water pump
My box is 10+ years old an I have never changed the water pump. What are the dangers of this....?
jmatta 12-16-2010 04:58 PM
According to Jake Raby (Flat 6 Innovations), the highest risk is the plastic impellers breaking and lodging in the cooling passages in the cylinder head. Not so much mileage, but age can make the plastic brittle; I would venture you are on borrowed time. My 3.2 is going to be 9 years old this spring with only 19k miles on the clock...I plan to replace the pump just as a precaution.
jaykay 12-16-2010 05:01 PM
Great more plastic parts..........agreed the thing needs to come out. Had no clue the impeller was plastic
Idaho Red Rocket 3 12-16-2010 05:30 PM
I've been thinking of changing mine for the same reason. 12+ years old with 127k miles. NAPA has a reman for $144 or new for $158. Has anybody used one of these from NAPA ?
Why cant we get a metal impeller replacement ?
kpm 12-17-2010 08:16 AM
I'd double check that "new" price. I sell a reman for $160.00 and the new pump is $358.00.
dsisco 12-17-2010 04:00 PM
just changed mine, got it new for around $200
go to sonnen porsche, while your down there i recommend changing to the low temp thermo from LN
JTP 12-17-2010 04:08 PM
Get a genuine Porsche water pump. Why would you risk your engine and go with a remanufactured pump?
I'm all for saving money but some things are worth spending the extra for the genuine article.
Soetekouw 12-17-2010 04:59 PM
Does the replacement water pump have non-plastic impellers? Or are we just replacing one pump for another pump with the same plastic impellers? So, if we bought a Porsche OEM pump, what are we gaining?
tonycarreon 12-17-2010 05:37 PM
i think most feel the plastic is superior than the metal in this case, as the metal will expand and cause leaking.
but it's possible i'm crazy and thinking of sonething else.
JTP 12-17-2010 05:48 PM
From a thread in October:
Originally Posted by Jake Raby
I am not selling a water pump with a metal impeller.. The main reason is IF the bearing in one of these units goes bad it will chew into the engine block and destroy it.
At the current state of development using a quality pump with a plastic impeller, but changing it out every 2-3 years is the best policy.
urban_legend 12-17-2010 06:04 PM
The future is plastics - well at least it was in 1967
Here is what a "lightly" used pump looks like.
jaykay 12-17-2010 09:59 PM
okay...... that got my attention!
Idaho Red Rocket 3 12-18-2010 09:47 AM
You are correct KPM, I did make a mistake on the price for the new water pump from Napa. Their web site says it is $154. I think my local store quoted me the $158.
So the question is still unanswered. Has anybody tried one of these from Napa ?
Will I be the first to do so ?
Also, Please help me understand the reason the 160 degrees thermostat is better than the 190. It is my understanding that an engine not up to at least 180 degrees does not opperate at peak efficiency. Give me a little more detailed information so I can give my car the best treatment too.
Soetekouw 12-18-2010 09:51 AM
So, if I get the gist of this thread, we replace the water pump with a Porsche OEM pump (plastic) impeller (JTP) every 2-3 years (Jake).
Well, I guess I am due to replace mine (4 years). Who has the best price on a new OEM pump. My Boxster is a 2007. What do you think it will cost me to have the dealer replace it?
Mark_T 12-18-2010 10:36 AM
I know this has been said many times before, but also look at changing your front motor mount at the same time.
jaykay 12-20-2010 08:12 PM
Yes......I keep hearing this and always wonder what the deal is. I suppose there is a huge polymer section to it and it is susceptable to embrittlment over time? I am at 11 years and have never felt anything like the engine shifting around. I guess I would have to be out of the car and maybe have a look. Is there a 997 upgraded mount that all are using? Is it fair to say that there is no additional labour in getting at the mount while you are at the pump? I would like to do these myself if they are feasible using jack stands....
clickman 12-20-2010 11:16 PM
987, not 997
shlim8 12-22-2010 07:33 AM
I just had my water pump changed on my 01 box with 37k km.
The plastic impellers were still perfect, the pump seems in pretty good shape.
But at least now I've gotten rid of one potential problem...
Also had the low temp thermostat put in.... temperature is now usually slightly above 80 degrees C, goes up to approx 90 degrees when pushed hard (same as prev). No other noticeable difference though.
I changed the serpentine belt at the same time, although it still looked good. And was very glad I did, got rid of the whining noise especially when the weather is cooler or engine is cold..
Bladecutter 12-22-2010 08:28 AM
I installed the Napa remanufactured pump just after Labor Day, when mine went bye-bye during a drive through the Rockies.
So far, so good.
Since its a lifetime warranty from Napa, I have more confidence in it, than something that came from some other type of shop that has part suppliers of less than stellar quality.
Plus, they also had the lowest core charge out of all the sources I looked at.
BC.
Jake Raby 12-22-2010 09:20 AM
Change all water pumps after 3 years of service, despite mileage. After 3 years the heat, coolant and time in service have proven to create issues that cost engines.
If you drive your car 300 miles in 3 years, you still must change the pump to avoid the costly failures associated with the partial water pump failure that put 12 cars from 11 different states in my parking lot right now.
