Old 11-23-2010, 08:02 AM   #1
alarm problem after radio swap
I just replaced the Becker unit with a Kenwood double DIN. Now, whenever I lock the doors with the fob, I get a chirp from the horn. I assume it is because it is sensing the Becker not installed.
Is there a fix?
Also, I see quite a few pix of double DIN installs. Where can I find a nice frame to fit the cutout?
http://i1215.photobucket.com/albums/...dall/Car-1.jpg
2001 S Speed Yellow, matching interior, German Plates!!
Iflylow is offline   Reply With Quote
Old 11-23-2010, 10:40 AM   #2
For a double din trim kit go to Ebay and search for Porsche Double Din - I bought one from Euro Motorsport that worked very well.
Al in Seattle
2000 Boxster S
Ocean Blue, Black Interior, Black Top
60,000 miles
alvinlee is offline   Reply With Quote
Old 11-23-2010, 11:14 AM   #3
Is there a fix?
There is a ground contact on the Becker's frame, with the radio removed, it is not grounded, leading to the alarm chirp. Locate it and ground it, the chirp will stop.....
Old 11-24-2010, 09:10 AM   #4
I may be wrong but I think there is also a little non-conductive pad on the side of the radio, so if someone try to 'SLIDE' the radio out.. the ground contact will occure and start the alarm..
I suggest simply taking a look at those trigger and create contact or isolation to make it happy
vipola is offline   Reply With Quote
