Old 11-20-2010, 06:16 PM   #1
KevinH1990's Avatar
Change spark plugs with car on ramps?
Is it possible to change the spark plugs with the car on ramps instead of removing the rear wheels?
When I changed a coil pack a few months ago, I put the car on a jack stand and removed the wheel and fender liner for access. I saw a post on Rennlist where one of the posters said that he had done the job on Rhino ramps.
When I was working on my car, I just assumed I needed to remove the wheel. I guess I could just roll the car up on the ramps and see how tight it is.
Personally, I would rather use ramps if the access won't be too tight. I'd like to hear from folks who have personally used ramps and find out if there are any problems or tips to be aware of.
Old 11-21-2010, 02:47 AM   #2
I would venture to say that it is possible to change plugs with the tires on... maybe on a lift. But doing it on the floor with a set a ramps would be a pretty tight fit. Even with the tires off, the front plugs are a squeze to get at.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 11-21-2010, 07:12 AM   #3
It is so much easier with the wheel off that I would not do it any other way.
You have much better visibility and you can make sure that you treads on the spark plug are going in correctly.
A easy job can turn into a disaster by skipping a step IMO.
I jacked up one side with the wheel removed and put a jack stand under there as well.
Lot more room to work and see!
2004 Boxster S Anniversary ed, hard top:
SOLD
jditom is offline   Reply With Quote
Old 11-21-2010, 03:11 PM   #4
Steve Tinker's Avatar
Ahhh - one of the rare Porsche 7 plug engines in your car......
2001 MV Agusta F4.
Old 11-21-2010, 06:18 PM   #5
That seventh cylinder....
Is sure burning clean.
Norminhouston is offline   Reply With Quote
Old 11-22-2010, 04:51 AM   #6
You guys don't miss anything
Pic of the new to me ride.
SOLD
