Old 07-05-2011, 05:43 PM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
HELP.. Xenon light switch broke, lights don't work. Getting dark..
My switch for my head lights has been acting
Up lately. Every time I try and turn on the lights they will flicker. So I would have to turn it on and off until they come on. And today it's seems done completely, I'll turn it to the on switch and it will make a sound and nothing..... What to do? I'm gonna be driving in the night soon....
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 07-05-2011, 08:04 PM   #2
More than likely it is the ignition switch...try wiggling the key/turning it just slightly backward. Had the SAME thing happen when I installed my xenons, turned out it was the ignition switch.
tightbox is offline   Reply With Quote
Old 07-06-2011, 07:25 AM   #3
ppbon's Avatar
It's either the light's switch or the ignition switch.
I'd venture a guess that it's the former.
Here are the DIY instructions to replace them both:
http://www.pedrosgarage.com/Site_3/Replace_Lights_Switch.html
http://www.pedrosgarage.com/Site_3/Replace_Ignition_Switch.html
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 07-07-2011, 01:59 PM   #4
2001 RUF 3800S
Thanks!
I'm leaning towards the light switch. It's on order.
I'll report back.
IG: RUF3800S
Old 07-10-2011, 08:31 AM   #5
I got the same problem as you, it was the light switch, i remove it and clean it with contact cleaner and that resolve the problem.
Pierre is offline   Reply With Quote
