Old 05-13-2005, 03:58 PM   #1
One more brake question.
I put new pads on a few days ago. At the same time I resurfaced the rotors and since the front left have started to squeal. (Like a warning tab) The brakes are surging also when I stomp on them anyone with an idea on what it could be. Thanks
JP-s-in st. louis is offline   Reply With Quote
Old 05-13-2005, 04:20 PM   #2
Brucelee's Avatar
Talking
These rotors don't resurface very well. My bet is that you need new ones.
Let us know if that is the case!
Old 05-13-2005, 07:07 PM   #3
donv's Avatar
You may well need new rotors... but first, did you ensure the wheels were torqued properly (with a torque wrench, not a calibrated elbow ) when you did the job originally? Is there any way you could have got grease or some other type of contamination on the pads or rotors when you did the work? If there is any contamination, you could use some brake cleaner to try and remove it (be careful with the cleaner, if you use one of the aggressive ones).
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
