Old 11-07-2010, 03:24 PM   #1
Convertible Top problem
1999 Boxster
Sometimes my soft top works, and then sometimes it doesn't. Checked my fuses, they are good. Would a relay cause it to sometimes work? I put it down for one of those rare fall hot days and now it won't go back up, Ughhhhhh!
brooksviewpro is offline   Reply With Quote
Old 11-07-2010, 05:02 PM   #2
Most common reason is the handbrake switch. Check and see if the dashboard light goes on when you engage the brake - if it doesn't than you have your problem.
This same question has been answered many times in this forum. Try doing a search and you'll find lots of info.
'99 black 986
Old 11-07-2010, 05:20 PM   #3
Jaxonalden's Avatar
You could always take the safety micro-switches out of the loop by installing a SmartTop controller.
http://eagleday.stores.yahoo.net/ne986enrocom.html
