Old 10-24-2010, 10:54 AM   #1
Help with interior lights on a 2000 base
New to the Boxster community. None of the interior lights seems to work (front storage, center windshield, or door) UNLESS the ignition is switched on. Then they work fine, but I cannot get them to illuminate when either door is opened without the ignition being on. What am I missing?
boxstervette is offline   Reply With Quote
Old 10-24-2010, 11:43 AM   #2
Same thing on my 2000 Boxster S... it is in "transport" mode still. The dealer will have to program it out of that mode. I guess it is for when they ship the cars over so the battery does not die on the way.
David - San Jose, CA
Current: 2010 Touareg V6 TDI, stock for now...
Current: 2000 Boxster S, stock for now...
Former: 2004 Porsche Cayenne Turbo... too many issues!
Former: 1999 996 C2, sorely missed
Reborn996 is offline   Reply With Quote
Old 02-02-2011, 05:28 AM   #3
Did this solve the problem? I have the same issue.. Driving me mad
Erik N is offline   Reply With Quote
Old 02-02-2011, 08:23 AM   #4
I had the same issue with my 2000 Boxster S, took it to the dealer and got them to take it out of transport mode...All is good now!
John
CasualCarnivore is offline   Reply With Quote
Old 02-02-2011, 09:45 AM   #5
Did the dealer charge you? Or did they oblige because it only takes 2 minutes to do?
Old 02-02-2011, 11:53 AM   #6
Originally Posted by coolbreeze551
Did the dealer charge you? Or did the oblige because it only takes 2 minutes to do?
Hahaha...of course my Porsche dealer charged me, 1/2 labour!
Old 06-07-2013, 05:29 AM   #7
Benjamin's Avatar
Sorry to dig up an old thread, but I was wondering if there were a common cause for all of our cars to revert back to transport mode (my 2000 S is doing it too). The closest dealer for me is over an hour away, and they (claiming over the phone they had never heard of this problem) said they would do it for $100. In calling around to independent shops in my city, one of them mentioned that they had seen this before and it seemed to be linked to when your battery goes dead. Not necessarily being disconnected for service work, but for instance leaving the lights on and your battery slowly goes dead. That did happen to me about a week after I bought the car, and to be honest, I don't remember if the interior lights came on correctly before hand.
Has anyone else had a dead battery experience just prior to noticing the problem?
Also, I've noticed that I can't store a new position in my memory seat. I never tried it before the dead battery, so maybe it never worked. I don't like the rear view mirror going down automatically because it's never useful and about half of the time it doesn't come back up, so I have to use the mirror adjuster to bring it back up.
Third, my brake lights don't work with the ignition off. I don't know if that's another symptom of transport mode, or it's supposed to be that way. On every other non-Porsche I've had the brake lights always work.
Fourth, (I keep remembering things), the central locks button on the dash doesn't work with either of the doors open? Again, doesn't seem like it should be that way.
I haven't checked the fuel door, but it may very well be not locking.
Benjamin
2000 986 S - "The Black Widow"
Benjamin is offline   Reply With Quote
Old 06-07-2013, 06:44 AM   #8
Multi-Boxer Driver
Deserion's Avatar
This is generally how German cars work. I've never had a German car (Volkswagen, Mercedes, or Porsche) that had the brake lights come on when the car is shut off. This is normal.
You cannot lock the doors if the driver's door is open. It's a feature on most (if not all) cars to help keep you from locking the keys inside if using the lock switch. Normal.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-07-2013, 06:49 AM   #9
Benjamin's Avatar
True, but wouldn't it be a bit more convenient to be able to lock the car on the way out without using the key or the fob? So what can you do with the button? Lock the car while you're in it? I don't know why I would want to do that.
On my Cobalt, you need to push the lock button twice if the door is open, and then it will lock.
