Old 10-17-2010, 10:14 PM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
Squeel sound between shifting. Stage 3 clutch/Aasco lightweight flywheel
I installed the stage 3 spec clutch and aasco lightweight flywheel at the start of the summer and ever since i noticed once in a while between shifting wether its downshifting or upshifting any rpms i i would get a squeel sound when letting off the clutch, 3500km later since the set up the same sound. any ideas?
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 10-18-2010, 02:13 AM   #2
Engine Surgeon
Yep.. That's disc engagement and it's totally normal for such an aggressive set up. You must be making a whole lit of power to need that arrangement.
Race clutch set ups have some negative aspects, this is one of them.
US Patent 8,992,089 &
US Patent 9,416,697
Old 10-18-2010, 01:37 PM   #3
2001 RUF 3800S
Thanks Jake, yeah theres a lot of negatives with this setup. Take off is a pain, you need to rev it high then slowly disengage the clutch or else it will be a bumpy take off.
If I had to do it again, I wouldnt. Good thing I drive this very rarely.
IG: RUF3800S
Old 10-18-2010, 02:08 PM   #4
Engine Surgeon
Been there.. My 996 Land Speed car has a similar arrangement.
US Patent 9,416,697
Old 10-21-2010, 02:43 PM   #5
2001 RUF 3800S
I guess that makes me feel a little better that you had the same issues. I always thought something was wrong. I hate the side effects of this setup.
IG: RUF3800S
