rear plastic window
i have a damaged rear plastic window on my 2000 boxster.any suggestions where is the cheapest to get a replacement.i have looked and cant find any less than 200.much apriciated
tickster, july 2010 issue of 911&Porsche World Mag did an article on plastic boxster rear windows and replcement, their article went through the replacement process and used car hood warehouse in chessington surrey 225. supplied and fitted inc victim added tax.
their website is under the same name as the company. its a way from north wales, but at least it should be a proper job, i've seen some with some nasty replacement jobs and you should use someone expeeinced with boxsters using good quality plastic not ome of the chearer garbage out there. good luck. post the results of what you find and what you do. |
| All times are GMT -8. The time now is 03:05 PM. |
