Old 08-31-2010, 02:32 PM   #1
Question Help ...
Hi there, been hanging around for a while now and never really had anything of value to say. However now i need some help/advice.
i have a 97 2.5 tiptronic boxster, and i love it, however tonight as i drove my wife aroundfor an hour or so a weird problem started to happen.
if i revved the car over 2500, i know shocking i would thrash it like that, the ABS and the Battery light came on, when the revs drop below 2500 they go out.
could this be an alternator/battery problem?
cheers
Jonathan
jrabarton is offline   Reply With Quote
Old 08-31-2010, 03:34 PM   #2
Could be your alternator is going bad or that your serpentine belt is slipping (due to a worn belt or weak tensioner).
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
Old 08-31-2010, 07:21 PM   #3
Dave S.'s Avatar
I don't know how Boxsters are wired, but I had a similar symptom on another car and it was the voltage regulator in the alternator failing. It tested ok on a bench test, but was in early failure mode. I had that alternator rebuilt and it worked perfectly again.
Dave S.
2003 Boxster S
Old 08-31-2010, 07:23 PM   #4
help
I just went trough the very same thing.Original alternator stopped charging ABS and BATT light came on,I replaced it with a rebuild unit with a bad bearing which made me think I had a bad ISB . Pin pointed the noise to the alt. Replaced alternator again, this time every time the engine turned over 3K both ABS and BATT lights came on .Now on alternator #4 every thing is back to normal. Silver99
pushrodracer is offline   Reply With Quote
Old 09-01-2010, 05:27 AM   #5
thanks to everyones advice so far.
I'm getting a new alternator fitted at the weekend, I'll take some pictures and post them all up too if i remember. although i wont be fitting it myself i'm sure my pet mechanic wont mind me snapping over his shoulder.
Old 09-01-2010, 07:46 AM   #6
I have this...
http://www.amazon.com/Equus-3721-Battery-Charging-Monitor/dp/B000EVWDU0/ref=sr_1_3?ie=UTF8&s=automotive&qid=1283351845&sr=8-3
If the alternator is on its last leg, the battery charge may be low as well.
I have this tool and seems to work as advertised.
mikehkang is offline   Reply With Quote
Old 09-01-2010, 10:06 AM   #7
Lil bastard's Avatar
Increasingly today, alternators are not meant to charge the battery, they are meant to replace that charge which the battery spent on starting, nothing more. Certainly not to 'deep charge' it. There are so many other electronic compenents in a car today that compete for the alternator output. This makes it more important than ever that your battery is in top form.
A bad battery can ruin an alternator in several ways; It makes the alternator work harder and longer, resulting in 'hotter' than it was ideally designed for. Also, the battery is supposed to act like a buffer to smooth out current fluctuations, if not in top form, it cannot do this and the alternator (or more specifically the diode pack, aka voltage regulator) suffers.
If it were me, I'd really consider a battery replacement along with the alternator.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 09-01-2010, 02:44 PM   #8
thats good idea, i took the box to the mechanic today and while he was chatting on his mobile, i used his tools to remove the access hatch ( i know him quite well and he is always encouraging me to get my hands dirty) I was nearly taking out the alternator before my wife pointed out i killed a MkII scirocco changing an alternator a few years ago. so i stopped
the alternator will be on the test bench in the morning and shoudl be refurbed by the end of the day.
wooo hooo
now i just need a new exhaust as it started blowing on the way to the garage ....
