Old 08-30-2010, 02:20 PM   #1
Interior lights not turning on
My interior analog gauge lights are not turning on when I put the headlights on. This includes the tachometer, speedometer, the temp and gas gauge. The digital gauges underneath do get dimmer though. Headlights are working fine and all the lights in the center console work fine.
Is it just a bulb that gave out? Ignition problem? How do I even take out the gauges to replace a bulb?
Lordblood is offline   Reply With Quote
Old 08-30-2010, 02:38 PM   #2
07 Carrera S Cab
Boxtaboy's Avatar
How to remove instrument cluster: http://boxsters.addr.com/hacks/cluster.htm
Bulbs: http://www.renntech.org/forums/index.php?showtopic=1827&st=0&p=8151&#entry8151
Old 08-30-2010, 05:08 PM   #3
Originally Posted by Boxtaboy
This then cannot be a bulb issue because all the bulbs went out at the same time.
Wiring? The only change I made recently was changing my stereo head unit.
