Old 03-25-2010, 08:16 PM   #1
Transmission fluid change
I am changing the transmission fluid and filter. I am not sure where the filler plug is on the transmission. Can some wounderful Porsche owner please send me a picture of the filler plug so I don't waste any more time.
I have a 2002 Boxster with Tiptronic transmission.
Thank you for any help
msiclari6 is offline   Reply With Quote
Old 03-26-2010, 03:15 AM   #2
I don't have a photo of its location but it is on top of the case. I use a dedicated tank sprayer( one for insecticides and such) , and have put on a J shaped piece of copper tubing in place of the spray head. This allows me to get it into the fill hole. There are numerous DIY write-ups on this. I have a 98 Tip with about the same mileage and have done it twice already. PITA but I think necessary. Ed
cvhs18472 is offline   Reply With Quote
Old 03-26-2010, 05:28 AM   #3
jcb986's Avatar
Be sure you do it correctly or you're out for a new transmission. :dance:
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 08-09-2010, 02:47 PM   #4
transmission fluid
Hello
Looking for the location to add tranny fluid, Can anyone help me out
Thank you
Roy
Roy Senior is offline   Reply With Quote
Old 08-09-2010, 03:35 PM   #5
Guys, this has been covered before; the Tip has two plugs on the bottom of the pan, one is a drain, the other is a fill plug.............yes, you read that correctly.............
Old 08-10-2010, 05:33 AM   #6
jcb986's Avatar
Go to Pelican Parts Tech area:
http://www.pelicanparts.com//boxster/boxster_tech.htm
