Old 07-27-2010, 10:01 AM   #1
window jumping
From outside the car when I operate the driver's outside door handle the window correctly drops and the door can be properly opened. However, when at any stage I release the handle the window goes back up (which the passenger side does not do) preventing closure of the door.
Similarly from the inside, I cannot pull close close the door because the window fouls on the hood; the window remains up unless I operate the inside handle.
I can cheat to get the door to close by pulling slightly the handle whilst pushing (ie slamming) the door closed.
Is this merely a 'programming error'or worse?
1999 986
srborthwick is offline   Reply With Quote
Old 07-27-2010, 05:25 PM   #2
there's lots of info and discussion. search on 'window'
also the link below may assist you
good luck
http://www.ppbb.com/phorum/read.php?19,1565400,1565407also
sb01box is offline   Reply With Quote
Old 07-27-2010, 07:45 PM   #3
MN 986's Avatar
I have had this problem. Everything you need to know is in the link below and in the link posted by sb01box.
Door window drops but immediately jumps back up
Good luck on the repair!
MN 986 is offline   Reply With Quote
