04-20-2005, 06:36 PM
Lowering the Box...
So right now I have the 996 turbo front on my car. It sits a lot lower than the stock front bumper. I'll be damned if I don't have to drive the thing like it's a lowered Honda...sideways and slow out of driveways. Not my thing, the stock front is going back on. It looks great, but I am more of a believer that form follows function.
With that in mind, how does the Box perform with a set of lowering springs? I currently have a wholesale account with a performance company. I don't have much time to run the business these days, so I am closing it down. I may just order up some products for my Box before I close down...namely some H&R sport springs, along with H&R front and rear sway bars.
They are a 1" drop, and with the rounded front bumper, I will still be able to drive it like it's normal...it'll just have a bit more of an aggressive stance and should handle a lot nicer. I will also be replacing my tires soon, probably some P-Zero's.
Anyone here lower their Box? Impressions? Gracias...
04-20-2005, 07:24 PM
What is wrong with the handling now?
04-20-2005, 07:36 PM
Nothing whatsoever...but it could be better. Actually, it handles better than the NSX I drive half of the time...FAR better...hah. But I figure since I am going to close out this account, I may as well capitalize.
www.matt3t4.com
04-20-2005, 07:46 PM
Morelli, on other threads you'll see that lowering the boxster is hell on your tires. It wears them out quickly. Now this could be an isolated incident from the guys on this forum who posted rapid tire wear, but it sure does make sense.
Hopefully, other boxster owners who have lowered their cars can chime in on this thread and give you better input. I'm a strong believer in leaving my Boxster stock as modifications seem to make the car a very high maintenance driving experience.
Anyone want to chime in for Morelli who has lowered their box and has had no ill side effects?
04-20-2005, 11:26 PM
Originally Posted by RandallNeighbour
Morelli, on other threads you'll see that lowering the boxster is hell on your tires. It wears them out quickly. ...
When you lower the car without touching the toe/camber settings, you will be running more negative camber. Hence, the insides of the tires will wear faster than the outside. I experienced this with my M Coupe which did not have camber adjustments in the rear. I had to install (ie. weld on) camber and toe kits (toe vary with camber changes) to compensate for this.
For the Boxster, I'm sure the rear camber can be adjusted to suit the lowered ride. The concern is how much can it be adjusted. Same goes for the toe.
My personal opinion is if you're not going to track the car often, a set of aftermarket shocks and springs would suffice. I will only go for coilovers like PSS9 if I frequent the track every month. For my M Coupe, I made do with a set of Koni shocks and H&R springs since I track about twice a year only.
Having said that, I would not recommend just changing the springs alone and using it with the stock shocks. Read somewhere that aftermarket springs are best matched with similar shocks because of the need for increased damping effect.
04-21-2005, 07:06 AM
By the way if you do plan to Autocross with your new suspsension PSS9 will bump you up a whole class with most racing clubs and you'll be competing against much more powerful cars. So from a competitive stand point its not really suited for Autocross unless you are doing it just to improve as a driver and not so concerned with placing. But around here, the guys in the more powerful cars are also the much more experienced drivers.
By the way Coilvovers are not overkill for a road car that never sees a track. Its a far better method of fine tunning ride height. When you lower that car on your new H&R or Eibach springs you are effectively stuck with that height like it or not. And if down the line you start to grow weary of the new lower height and miss the old more comfortable height, with colivovers you can return it to stock height in an hour. Reinstalling your old springs will take much longer and more $$$.
The best thing to do is go to a Porsche Club event either Autocross or Rallye (now that the season is back) and find a Boxster owner with a lowered suspension and similar wheels and tires. Ask for a ride along and you'll have a far better idea than just ordering from a catalog and crossing your fingers.
My two cents is that the car handles great as is. There is no guarantee that it will handle better if it is lower. In fact, you are already concerned about ground clearance, ie the issue with the bumper.
Perhaps you should spend the money on a short shift kit?
IMHO!
04-20-2005, 08:41 PM
I think tinkering with the suspension is not something you want to skimp on. I mean its ok with an inexpensive car like the Miata or a Civic but this a Porsche man! It deserves the best set up you can afford. Go with a full coilover system.
like the Billstein PSS 9. Its $1900 delivered from the link below. The psosibilities in finding the right balance between comfort and performance are enless. I only wish I had a lift because I could spend the whole day charting heghts with compresions. :dance: When a car is dialed in perfectly the carving sensation is fantastic. I spent at least $2000 on my Miata's suspension until I found the perfect set up and it was the best thing I did to enjoy the driving experience. Adjusting that little knob for different settings was my favourite thing about the car. Soft in the City hard on the highway.
Billstein PSS9
The thing is if you go with just lowering springs its a crap shoot. Will your $50,000 car like the new stance? I played this gamble several times and like me you will learn that it can be a disaster. There are many factors that can affect the way your car will take to certain springs unrelated to just the spring rates. How heavy are your wheels and tires? What sways are you running? How worn are your shocks? Suspensions are very sensitive and tinkering with it without the ability to adjust ride height/center of gravity is not something I would want to gamble a $400-$600 mechanic's fee on. With the coilovers you can return the car to the stock height and set teh shocks to full soft. and gradually lower it until you hit the sweetspot in looks and comfort.
04-20-2005, 11:02 PM
Both H&R and Eibach make quality products and I believe both are TUV approved. The Boxster runs a basic Macpherson suspension...not magic fairy dust. Throwing on a different set of springs will change the dynamics but it isn't going to be too much of a crapshoot.
If you do a lot of roadracing (track), then the PSS9 would be a good choice allowing you to adjust ride heights, valving characteristics, and corner balance the car. If you do a little track/autocross, want a lowered stance yet want some compliance on the street, then the lowering springs fit that description quite nicely and a coilover system is somewhat overkill. What's "the best" for the track is not always "the best" for an all around application IMHO.
I use to run H&R springs with Bilstein Sports on my M3 while a buddy ran PSS9 on his M3. Even at full soft the ride of the coilover system was much more harsh on the street.
Interestingly, the Boxster supposedly comes with linear rate springs whereas the aftermarket springs (e.g. Eibach and H&R) are progressive rate.
Check the Boxster racing board. Those guys have tried it all as far as suspension is concerned...
