Old 06-30-2010, 11:17 AM   #1
Send a message via AIM to 986rgt
Anyone that has added the aerokit 2 wing to their car...
Could I see a pic of the wing on the car? I was also wondering what you used as a measurement from the rear edge of the trunk lid to the base of the wing? Also what did you do to disable the retractable wing? Any help would be great. Thanks
Steve
986rgt is offline   Reply With Quote
Old 06-30-2010, 12:12 PM   #2
Mine has it but it was ordered with the car at the time. If you need pics/measurements just let me know. From what I know the wing was disabled too but I can use the buttons to extend/retract it when I want. Not sure at 75mph what happens as I cannot see what is going on in the rear.
CR
crod is offline   Reply With Quote
Old 06-30-2010, 12:21 PM   #3
What year is your Boxster? Aero II Wing on a 2003/2004 should already have hole marks ready for drilling under the lid.
I added an Aero I wing, I liked it better. I had to do the measurements, not too hard.
As for disabling the retractable wing, yes, you’ll need to order this part# 986-612-981-23, cost about $16.
Then follow these instructions, takes about 10 min to do:
5.6.2 Remove the rear luggage compartment lining of the rear luggage compartment and unclip the 6-
pin plug connection to the drive of the retractable spoiler (located to the left of the lock on the
bottom of the retractable spoiler carrier).
5.6.3 Disconnect the 6-pin plug connection and establish the plug connection with the 6-pin cable link.
5.6.4 Clip in the 6-pin plug connection onto the bottom of the carrier again.
6. Concluding work.
Take your time, measure twice, drill once!!!
-Cesar
03' 986 Midnight Blue Metallic
_____________________________________________
Gemballa Lowering Springs | 18” Carrera Light Wheels | Painted Calipers
14/18 H&R Spacers | Aero Wing & Rockers | Powder Coated Exhaust
Creator of CRIOS exhaust mod | De-Snorkeled | De-Ambered
Light Weight Flywheel | Tinted Windows and Windscreen
Painted Bumperettes | 550 Spyder Grille Kit
http://lh5.ggpht.com/_9sTq_sN1KDw/Si...2009%20055.jpg
crios is offline   Reply With Quote
Old 06-30-2010, 12:36 PM   #4
This is the best example on how measure/drill properly so the hole lines up:
http://www.youtube.com/watch?v=lbwnq20Avxs
-Cesar
Old 07-05-2010, 06:56 PM   #5
I'm guessing about 4" from the rear edge of the decklid to the trailing edge of the wing supports? Can anyone with an aerokit 2 verify this for me? I would really appreciate it.
Steve
Old 07-11-2010, 04:19 PM   #6
Anyone?....
Old 07-11-2010, 05:25 PM   #7
07 Carrera S Cab
Boxtaboy's Avatar
Steve, I'd just email Maurice, and ask him to bring a measuring tape with him when he meets up with Jaay on Tuesday at a Porsche event. Jaay has a factory aerokit on his car, including the wing.
Old 07-11-2010, 06:38 PM   #8
Thanks Rich, but if I remember, Jay has the aerokit 1 wing not the second version, but if he does, I thank you guys in advance.
Steve
Old 07-12-2010, 01:00 AM   #9
07 Carrera S Cab
Boxtaboy's Avatar
Ah, you may be right. Didn't know the wing was different btw 1 and 2.
Old 07-12-2010, 04:28 AM   #10
Spoiler (Revised with measurements)
The bottom edge is exactly 3" from the bottom lid and the bottom edges are 5" from the edge on both sides
It's the ‘97-04.5 Boxster new OEM Aero Kit Pelican part described as Boxster Wing & Hardware # 986 512 992 00.
It was on the car when purchased but appears to be high quality and good fit that matches well with the side skirts. Hope this helps. I have not disabled the spoiler.
Burt
Ruby
'03 Artic Silver base Boxster
PSS9, short shifter, performance chip, upgraded to Navigation and bluetooth, side skirts and spoiler, power 8 way seats from 996
Ruby is offline   Reply With Quote
Old 07-12-2010, 05:26 AM   #11
JAAY's Avatar
I'm going to try and get to the legendporsche thing tonight. Ill bring a tape with me. But like RGT said I have a 1 wing. Rich Come out tonight
Old 07-12-2010, 06:30 AM   #12
07 Carrera S Cab
Boxtaboy's Avatar
All you folks with the AERO 2 wing, he doesn't need pictures of what the wing looks like on your car... He needs one of you to just take a tape measure to your wing's support columns, and measure how many inches it is to the trunklid's trailing edge. Can you do that for him so that he knows how to position the wing when he installs it?!
Jaay, sorry, but I can't make it tonight. Have fun man!
Old 07-12-2010, 06:53 AM   #13
Might I also sujest that when you mark the holes use a fine marker to make cross hairs slightly bigger than the drill size. Then use a small pilot drill first. Many people who don't drill metal often or if the drill is not properly sharpend will "walk the bit" and the hole will not be where it was marked. If you have cross hairs you can see if this is happening while you are drilling and make corrections so your hole doesn't end up in the wrong place.
Ken
SoCalKen is offline   Reply With Quote
Old 07-13-2010, 10:27 AM   #14
So I have found out after calling about 10 dealers and writing to PNA, that no one in Porsche knows how to install an aero 2 wing! WTF?! This is the response I got from Porsche:
Thank you for contacting Porsche Cars North America.
Although we would like to assist you with your inquiry regarding installation of an aero kit for your 1999 Boxster vehicle; we do have to advise you, that it is our recommendation to contact your local or preferred Authorized Porsche service department. We strongly encourage you to speak with a Porsche Service advisor or the Service Manager for furher details . There, you will be able to speak with a contact who will be able to offer their expertise in advising you accordingly, as we do not have a technical line to consult with regarding inquiries such as these.
Thank you again for your email - we wish you many more pleasurable driving miles behind the wheel of your Porsche!
Gee thanks, I never would have thought to call my dealer!
I'm now pleading with you guys with the aero 2 wing to get the measurement for me! Pretty please?
Steve
Old 07-15-2010, 07:39 PM   #15
Still hoping someone can help me out. I would really like to get this on my car before winter!
Steve
Old 07-15-2010, 08:14 PM   #16
Burt
Is that the aero kit I or the aero kit II spoiler? I have what looks like the same spoiler installed from the factory, what version they call it, I don't know.
Ken
Old 07-15-2010, 11:53 PM   #17
That's the aero kit 1 wing. The aero 2 wing looks kinda like the 996 GT3 wing.
Old 07-16-2010, 01:49 AM   #18
Rennzenn
j.fro's Avatar
Here's mine:
http://www.rennzenn.com/images/race_numbers.jpg
It's the aerokit 2 wing. The lip beneath it is one of the wings that mounts in place of the retractable spoiler. Like others, I had problems with the retractable wing's mounting points cracking. I had a body shop mold that wing into a fiberglass trunk lid, and I got rid of all of the retractable mechanism. Between the glass trunk lid and the removal of the retractable stuff, I had a net loss of about 25 pounds...and I've got more downforce at the rear from the new setup. And I love the way it looks.
