Old 06-21-2010, 11:40 AM   #1
brake wear light...
brake wear light started to come on intermitantly. replaced rotors and pads and sensors. do I need to reset the "brake wear light" or does replacing the sensors automatically take care of the light?
Thanks, Pat
02box is offline   Reply With Quote
Old 06-21-2010, 12:14 PM   #2
Once you replace the sensor that has had its protective cover worn away, then the light will go out.
If you can find the one sensor that has worn away, you only need to buy that one sensor.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
