Old 06-04-2010, 08:21 AM   #1
Jaak's Avatar
Question Rim Fitment 2002 S
Folks, I have a chance on the following rims and was wondering how well the fit would be and what spacers I would need"
Quality meets all TUV, DOT, JWL, VIA standards. Made in Italy
Finish: silver finish with polished lip
Rims Size: 18 X 8.0" front & 18 X 10.0" rear
Bolt Pattern: 5 X 130
Offset: 52mm front & 65 mm rear
Quantity: Set of four wheels and caps
Brand: New Classic mesh style wheels / Rims and Kumho Ectsa SPT tires
Kumho Tires: 2 x 225/40ZR18 Kumho Ecsta SPT 2 x 265/35ZR18 Kumho Ecsta SPT
Any assistance would be much appreciated!
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
Old 06-04-2010, 08:35 AM   #2
Jaak's Avatar
Looks like the rears ofset is not a go ... guess I'll have to pass ...
Old 06-04-2010, 08:43 AM   #3
ChrisZang's Avatar
you will need rear spacers
Old 06-04-2010, 08:52 AM   #4
Jaak's Avatar
Thanks for the reply!
I found out they need to be 20 mm and will need longer bolts and a bit of grinding & ty-wrapping ... Too much trouble and a possible safety issue as well.
Old 06-04-2010, 08:54 AM   #5
ChrisZang's Avatar
Ok, understood
Just for the record: If my memory serves me well you would actually need 25mm spacers (and even longer bolts)
Old 06-04-2010, 01:06 PM   #6
husker boxster's Avatar
Do we need to make a sticky that states 11" 65mm wheels will not work on a Box?
No offense to you Jaak, this is just the 3rd thread this week on the topic.
1989 928 S4 5 spd - black
Old 06-07-2010, 10:22 AM   #7
Jaak's Avatar
None taken ... mine was 10" 65mm ......
Issue is that several publications such as Bentley Manual state that it should "fit". They do not add that shimms & grinding & ty-wraps are required in order for them to "maybe" fit.
What I am looking for is a 18 inch rim (sport 2 type) that is basically bolt in without the extra. I had order from a PCA type in Alabama who shipped via Usless Parcel Service that lost 3 of the four and shipped the fourth to a wrong address three times ....
I lost out on a good deal ... it also came with almost new tires as well ....
Old 06-07-2010, 08:16 PM   #8
Actually, what would be the most helpful, in all seriousness, would be a sticky that lists the wheel sizes and offsets that WILL fit a 986/986S/987/987S, as well as the size of any spacers needed for a given application and the length of any longer-than stock wheel bolts needed. I'm sure it would be a long list (probably more akin to a spreadsheet), but it would cut down on these threads. Just a thought.
2002 Boxster S, 6 speed, Speed Yellow
Flat Six Innovations 3.8L Stage II Track Performer, RoW M030 Suspension, B&M Short Shift Kit, Fabspeed Bypass Pipes, FVD Brombacher "Sound Version" Muffler, UD Pulley, Low Temp T-Stat.
Banana S is offline   Reply With Quote
Old 06-08-2010, 07:28 AM   #9
ChrisZang's Avatar
I think that's a good idea.
Before we turn this into a full blown science project maybe we could make a sticky thread where everyone can post who has non OEM rim sizes on his Box. He should post the rims size together with spacer a bolt sizes
When we have gathered enough information we can start with the spreadsheet project.
Old 06-08-2010, 07:56 AM   #10
GTA_G20's Avatar
if you change your mind Jaak, I have HR 23mm spacers that I dont need and will sell cheap
2006 Audi A4 Avant 2.0t Quattro
1997 Boxster Glacier White w/facelift(gone but not forgotten)
2004 Boxster S 550 Spyder Anniversary Edition
GTA_G20 is offline   Reply With Quote
