-   -   1999 Boxster CEL (http://986forum.com/forums/boxster-general-discussions/25001-1999-boxster-cel.html)
jmcl 06-03-2010 06:46 AM
1997 Boxster CEL
Hi guys,
new to the forum.
My 1997 Boxster is misfiring. I read the codes and got P1319, P1314, P0300 and P0302).
I did a forum search for some of these codes (P1319 and P1314) and there are a few posts related to the MAF.
Since these codes point only to cylinder 2 does this mean that the MAF is ok and that this is a cylinder 2 related problem.
I just need a starting point or a strategy to diagnose this.
Any help is really welcome.
Regards,
John, Portugal
Motronic 5.2.2
Current Fault Codes
P1319
Factory Fault Code 62 - Misfire, emission related
P1314
Factory Fault Code 51 - Misfire, cylinder 2, emission related
P0300
Factory Fault Code 75 - Misfire damaging to catalytic converter
P0302
Factory Fault Code 64 - Misfire, cylinder 2, damaging to catalytic converter
jmcl 06-03-2010 07:36 AM
Originally Posted by jmcl
P1319
P1314
P0300
P0302
Found this post
http://www.boxsterforum.com/forums/showthread.php?t=24701
Sounds similar.
Should i change the ignition coils?
Maybe swapping the ignition coil on cylinder with other cylinder?
Any suggestion?
Txs.
John
extanker 06-03-2010 07:49 AM
have you looked at the spark plug yet ?
jmcl 06-03-2010 08:02 AM
They were recently replaced with brand new NGKs.
To be honest that is a very good sugestion.
I still have the old ones and I will try to fit and old one and retest.
Thanks!
John
paulv 06-03-2010 08:36 AM
Thanks!
John
John,
Instead of fitting the old spark plug back in to test, just swap the new plug in cylinder 2 with another cylinder and see if the code follows the plug.
Regards,
paul...
Topless 06-03-2010 09:05 AM
Sounds like cyl 2 plug, coil pack, or connectors just not seated properly. Probably an easy fix.
jmcl 06-05-2010 09:05 AM
Boxster Fixed
I'm happy to report that after replacing the coil pack on cylinder 2 everything is back to normal and the car is running great.
Thank you to users extanker, paulv and Topless for answering when I needed help.
Regards.
John
extanker 06-05-2010 09:12 AM
glad its fixed ...tanks for the get back
