Old 05-03-2010, 07:29 PM   #1
Alternator Mount
Hello,
Some of you may know from a recent thread of mine that I replaced my alternator due to electrical problems I was having and that fixed my problem.
However, I apparently did not tighten the idler pulley enough and the alternator came loose from it's position and I nearly had a very bad catastrophe. What I do have is a broken alternator mount plate (? correct part name - see pics below) and a few other minor problems.
I'm hoping someone can tell me what this part is actually called - the plate attached to the engine that provides a mounting point for the lower left alternator bolt.
'99 986 - 5 Spd, Triple Black, 19" Wheels, Debadged, Clear Side Markers, Updated Tail Lights, K&N Air Filter.
http://lh4.ggpht.com/_47QLEDGAzmg/S6...8/DSC_1652.JPG
skadakia15 is offline   Reply With Quote
Old 05-04-2010, 05:35 AM   #2
jcb986's Avatar
Anytime you remove a bolt you need to put a spot of blue lock tight on it then torque to specification. That looks like a water return with the alternator bracken made as a one piece. I would try a dismantler for the part.
I checked but could not find the part number, but it will be much cheaper from a dismantler.
http://www.partrequest.com/used+auto+parts/make/porsche/boxster
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
