Old 04-22-2010, 03:06 PM   #1
Dashboard lights (speedometer, clock and mileage) don’t turn off
I’ve had my 1999 Boxster for almost a month and this just started happening 3 days ago. When I turn off my Boxster and remove the key, the dash lights including the speedometer, clock and mileage reading no longer turn off. I don’t know if I accidentally changed a setting that I can change back, or if this is a problem? I’ve waited for 5 minutes and the lights stay on. The only way I can get the lights to turn off is to lock the car. Any suggestions or ideas?
thanks for your help.
my1999boxster is offline   Reply With Quote
Old 04-22-2010, 03:28 PM   #2
That's normal.
Dash will go off in about 5 min or if you lock the car.
I had same scare after I changed my ignition switch.. I noticed that dash lights will stay on unless I lock the car. If you leave your car for 5-10 min.. they will go off.
Sasha
sasha055 is offline   Reply With Quote
Old 04-22-2010, 06:51 PM   #3
Agreed, hadn't noticed this until I changed my ignition switch also but they do go off.
http://i240.photobucket.com/albums/f...r/carlit-1.jpg 2003 Boxster S
spyder803 is offline   Reply With Quote
Old 04-22-2010, 08:02 PM   #4
Lil bastard's Avatar
That is a sign of the ignition switch going bad - a $20 part and pretty easy to swap. Documented here lots of times.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 06-20-2010, 11:20 AM   #5
Cool 2000 porsche boxster
Hi so is it normal for dash board lights to stay on for 5 min or go off right after you pull the key out.
Thanks for any help
henry garcia is offline   Reply With Quote
Old 06-20-2010, 01:59 PM   #6
07 Carrera S Cab
Boxtaboy's Avatar
It is normal for the dash lights to stay on for 5 minutes after you pull out the key, unless you lock the car (in which case they go out right away). However, if the lights do not go out even after 5 minutes, then it could be that your clock reset/mileage reset knobs are stuck in the pushed in position, or your ignition switch is starting to act funny.
