Old 04-18-2010, 09:25 PM   #1
Leak From Coolant Manifold?
My 2003 S started to leak Coolant, I jacked up the car and poured some coolant in the resevior, if started to leak right away. I went under the car with a flashlight and somewhat pin pointed the leak I believe in the coolant manifold. It seems to be leaking from the seal.
Any advise ? Pointers?
I will have it towed to my house tomorrow and start working on it.
I truly hope it's not a cracked case.
Age 21- 914 smashed in the front, did the body work, painted it Guards Red, fun car.
Age 27 - Germany, 2 Ea. 924's
Age 28-37 - Bought 1966 912, pulled out of Dirt, re-build, dialy driver for 8 years.
Age 47 - 03 Boxster S Guards Red - Love it!
Future - Speedster Replica
JamesBorisPerez is offline   Reply With Quote
Old 04-19-2010, 06:48 AM   #2
ppbon's Avatar
I'm not sure what you mean by coolant manifold...
... generally coolant leaks come from:
• a cracked coolant reservoir (in the rear trunk)
• a bad water pump (on the lower front side of the engine)
• a leaky thermostat housing or bad gasket (next to the water pump)
• some loose hose clamp (multiple throughout the system)
• a cracked radiator (front corners)
• or the obvious, from the coolant overflow (generally because the system hasn't been bled of air).
Can you post a picture of where it's leaking?
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 04-19-2010, 07:32 AM   #3
I will attach a picture sometime this week when I get the car home. From your information I would say it a leak from the thermostate housing, it's in that area.
Thank You.
