Old 04-16-2010, 04:11 PM   #1
ok what's the trick...
...to removing the center caps without buying the ridiculously overpriced "Porsche removal tool"?
I tried 2 long ice-pick type devices in each hole and pried, rotated, squeeze, everything.. wouldn't budge.
what's the trick here?
just got a new set and am anxious to get em on!
stateofidleness is offline   Reply With Quote
Old 04-16-2010, 04:13 PM   #2
Remove the wheel and pop it from behind.
Old 04-16-2010, 04:44 PM   #3
that's a lot of work for such a small task
Old 04-16-2010, 04:45 PM   #4
There Is No Substitute.
rick3000's Avatar
Take a wire coat hanger, cut it and bend it into a U shape. Bend the last inch/inch and a half of each end of the U shaped wire 90°. Insert the wire into the two holes on the center cap, and pull.
Old 04-16-2010, 04:49 PM   #5
07 Carrera S Cab
Boxtaboy's Avatar
Rick's suggestion will work. You can also use a small L shaped Allen key to pull it off.
Old 04-16-2010, 05:07 PM   #6
to a T! snipped it right at the curves to keep the pre-made bends
mocked this up real quick for future visitors:
Thanks guys!
Old 04-16-2010, 06:32 PM   #7
Jaak's Avatar
You will have to tug on it a bit as it is a pressure fit. I used a hooked tool and pulled on it with a bit of force to get mine off. Allen key works wonders!!!
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
Old 04-20-2010, 12:02 AM   #8
+1
nothing easier than just removing your wheel.. dont scratch your pricey caps with...coat-hanger...
MIMA is offline   Reply With Quote
Old 04-20-2010, 04:41 AM   #9
+1 on wheel removal...also gives you an opportunity to clean and wax the inner portion that is usually difficult to access from the exterior.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
