Old 04-15-2010, 11:36 AM   #1
Jaak's Avatar
Fitment? Porsche 911 996 Carrera light 18 inch wheels
Wondering if this will fit my 2002 Boxster S?
Porsche 911 996 Carrera light 18 inch wheels. Set of 4 off a Carrera 4 $1200 CDN
fronts 8 inch offset 50 part #996 362 136 03
rears 10 inch offset 65 part#996 362 140 03
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
Old 04-15-2010, 12:53 PM   #2
With the 65 offset, the rears will require a 15mm spacer to clear.
Cheers,
ancster is offline   Reply With Quote
Old 04-15-2010, 12:55 PM   #3
Jaak's Avatar
Thanks ... manual called for 47 off set (rear) and Bently manual said 65 was OK ...
Old 04-15-2010, 08:21 PM   #4
You'll be tight with a 15mm spacer. I have 18 X 10 et47 on the rear of my car and the inside clearance is very tight. You'll also need to tie back the e-brake cable because it will rub otherwise.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 04-16-2010, 05:49 AM   #5
Jaak's Avatar
Thanks ... I'll pass on these as too much tinkering required.
