Old 04-15-2010, 02:13 AM   #1
Pain in the Rump
The weather around here , this week, was not so nice so I decided to change my water pump. There were a ton of posts about the water pump not lasting much more than 60K and I have about 64K on the car. I broke off one stud, lost 15oz of flesh from my hands and succeeded to extract a perfectly good water pump. There was nothing missing from the vanes, no sounds, no nothing. Doing preventative maintenance is such a crap shoot. Ed
cvhs18472 is offline   Reply With Quote
Old 04-15-2010, 08:46 AM   #2
dallison's Avatar
you got that right.
dallison is offline   Reply With Quote
Old 04-15-2010, 09:30 AM   #3
jcb986's Avatar
Why fix something that's not broken in the first place. My opinion of maintenance is, oil changes, air & cabin filter changes, pads when you need them, spark plugs at 60K along with the serpentine belt. Then if something breaks or fails, fix it. Most of this cars never have major problems...they really are well built.
Old Hippie Young Heart
Old 04-15-2010, 10:59 AM   #4
Anyone want a good water pump for $5 plus shipping? Ed
Old 04-15-2010, 01:56 PM   #5
husker boxster's Avatar
How many times has your car broken / become disabled in your driveway? 99% of the time it happens at the most inopportune time and place.
At least the poster has the piece of mind knowing his wp isn't blowing out anytime soon (unless the replacement part is defective).
1989 928 S4 5 spd - black
Old 04-15-2010, 02:04 PM   #6
Porscheectomy
Because when a water pump fails, it can leave little parts of itself throughout the cooling system. Making it impossible to make sure there won't be a block in the coolant system somewhere down the road.
Old 04-15-2010, 04:00 PM   #7
Where do you stert and stop
when it comes to maintenance?
I've over-maintained a lot of cars in my time, never got much out of it as the seller.
Start with the water pump and you go to the AOS, the IMS bearing, ignition switch, CV boots, ....
Old 04-16-2010, 06:32 AM   #8
Porscheectomy
I try to do preventative on parts that, if broken, will lead to more costly damage. The IMS and water pump are good examples. Things like the brake pads, CV joints, ignition switch, motor mount ect will wear out, but their failure won't ruin anything else, so I let those parts go before I'll bother to replace them. If you're paying attention to the signs of a broken AOS, that can also be replaced after it's broken but before it fouls the O2 sensors or leaves you stranded somewhere, so I'd wait on it as well.
