Engine Compartment Purge Fan Test
Is there an easy way to test the Engine Compartment Purge Fan?
Can I disconnect/unplug it and just put 12 Volts (DC) onto it to see if it works? Or, can I just use a heat gun/hair dryer on the sensor? Also, does anyone have a picture of the sensor and its location? Thanks, Mark |
Drive links version of a PIWIS or durametrics can turn it on and off if you have someone nearby that has either of those.
Unfortunately, I don't have access to a Drive links version of a PIWIS or a Durametrics unit.
Mark |
| All times are GMT -8. The time now is 05:09 PM. |
