Old 04-07-2010, 02:33 PM   #1
MAF Sensor
I have a 2000 boxster and need to purchase a mass air flow sensor; is the sensor with or without e- accelerator?
greenboxster is offline   Reply With Quote
Old 04-07-2010, 02:41 PM   #2
With e-Gas
see table at the end of this web page as there were multiple versions used in 2000 and it really matters which one you had.
Old 04-07-2010, 05:00 PM   #3
ChrisZang's Avatar
when I had to buy mine, ******************************** Arizona (or whatever they are called) had the best price
Old 12-02-2010, 01:25 PM   #4
Livin' a dream!
greenandtan's Avatar
to e-accelerator, or not to e-accelerator
Look under the front hood at a sticker in the middle at the front of the lid. The code for e-accelerator installed is M620 (or may just show 620). If you see that number that's the one you need.
Also, any advice out there on installing this guy, mine failed :ah:
greenandtan is offline   Reply With Quote
Old 12-07-2010, 09:01 AM   #5
Time has come to order a new MAF, car is a 2000 S (99 built) and I do not see "620" on that sticker under the front hood. Does that mean I should order a non e-accelerator version?
Can anyone confirm this?
panameras is offline   Reply With Quote
Old 12-07-2010, 10:32 AM   #6
Pana...look at the table at the end of this web page
it has chassis numbers and build dates and even the equivalent Bosch part numbers so you can save some $. Also some instructions.
If I can...anyone can. here
Old 12-07-2010, 11:32 PM   #7
Thumbs up
Thanks for the reply Mike. Turns out mine is e-gas early 2000, part no. 996.606.124.00
I'm ordering through ********************************,
http://www.************************************************************/search/cart.aspx?sid=055fq34512u1bgehkcellq45&makeid=800019@Porsche&modelid=1364396@BOXSTER%20S&year=2000&cid=22@Fuel%20%26%20Air%20System&gid=5068@Air%20Mass%20Sensor
Cheers
