Old 04-06-2010, 03:40 PM   #1
Humming noise from front right
I have a 2000 Boxster with 42,000 miles.There is an intermitent humming noise in the right front section.It usually happens cruising or turning hard right.I thought it could be bearings but what mixes me up is when I am cruising*40mph or so* and it happens I just lift my foot off the gas pedal very gently without slowing and the noise stops.To come back again.Sometimes it does not do it after driving for awhile.I was thinking of the fuel pump but why would it do it on a right turn only.My mecanic does not know and can't figure it out.It does not seem to get worst but I hate noise that I cannot identify.Any suggestions
lahalte is offline   Reply With Quote
Old 04-06-2010, 03:55 PM   #2
jcb986's Avatar
Well, my first thought would be a tire, but I also have had a noise and sometimes hard to pin point. Mine is actually the belt tensioner, or one of the 2 idler bearings. A few months ago I replace the serpentine belt, and when under power it made no noise but as I slowed down it appeared and when I stopped at idle it would not make the noise. I have driven off and on and now it's much louder and starting to squeal, now it will be easy to determine the exact part to be replaced. There is you radiator fan motor and maybe it could be causing your problem too. Let's us know what you find.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
