-   -   Break Fluid (http://986forum.com/forums/boxster-general-discussions/24318-break-fluid.html)
itoy 04-05-2010 08:13 AM
Brake Fluid
I'm planning to flush my brake fluid out of the system. I would like to know if it is OK to use the regular DOT 4 brake fluids available in Pepboys or Salvo. I have 2002 base boxster with automatic transmission. The Porsche dealer close to my area was closed for business and the nearest is 60 miles away. Thanks
tonycarreon 04-05-2010 08:51 AM
buy online. probably cheaper anyway.
pboxstercar 04-05-2010 09:03 AM
"break fluid" - Do you mean BRAKE fluid? I hope your mechanical skills don't BREAK your car.
landrovered 04-05-2010 10:37 AM
Break Fluid = Scotch or Bourbon
boxster6354 04-05-2010 10:51 AM
DOT 4
If flushing buy a different color than what you have, if Gold buy Blue, easy to tell when old fluid has flushed.
http://www.pelicanparts.com/catalog/shopcart/986M/POR_986M_BRKhyd_pg4.htm#item21
:cheers:
jcb986 04-05-2010 11:23 AM
If you are doing a flush, first check the color in your reservoir. If it's pale or yellow looking, get the blue. This way you can see the color change when bleeding. 1 can will do the trick. ;)
r9i8c7k 04-05-2010 11:32 AM
I used Prestone DOT 4 on my '02 986 and had no issues.
