Old 04-04-2010, 03:47 AM   #1
headlights
Hi, my inside beamlight is burnt from the bulb and the watts are ok 65 wt how can we fix this problem any idea's
baileymc is offline   Reply With Quote
Old 04-04-2010, 04:09 AM   #2
07 Carrera S Cab
Boxtaboy's Avatar
You're not supposed to use anything higher than 55w, which is probably why you have a burned lense. Put in a standard H7 55w replacement, and you should be fine.
Old 04-04-2010, 04:43 AM   #3
Headlights
thanks I'll check I;m sure it's a 55w
