Old 04-02-2010, 01:30 AM   #1
Roll Bar
Hi all, i'm looking to paint the roll bar on my boxster but i'm having trouble in finding any info or pics on how to remove it. Can anyone help?
Thanks.
roadrunner68 is offline   Reply With Quote
Old 04-02-2010, 04:44 AM   #2
There are 4 13MM nuts at the base of the rollbar on each side, just follow the pipes down to the base, you will need to unbolt the seatbelts as well. All of the work can be done with the top in the service position.
Good luck.
syncspeed is offline   Reply With Quote
Old 04-02-2010, 08:04 AM   #3
I've managed to do the the front bolts but it's the back ones i'm having trouble getting at. Looks as if some panels need to be removed somehow.
Old 04-02-2010, 08:44 AM   #4
The foam rubber pieces need to come out but that is easy.
