03-21-2010, 07:09 AM
new fuel filter, lower mpg
so i just replaced the fuel filter which had never been replaced, to my knowledge at 72k miles.
now the car is getting way worse mpg than before - from 24mpg before the change to 17mpg after the change. ( have filled up once since the change )
has anyone else noticed this? any recommendations? the car doesn't run bad and still seems to have the same acceleration as before. no bad idle and no abnormal "gasoline" smell.
03-21-2010, 09:28 AM
do you still have the old one? maybe put it in and see if your mileage goes up.
I just replaced mine and didn't notice any difference. I also replaced all of the 02 sensors.
03-21-2010, 09:39 AM
Have your driving habits or conditions changed at all since you swapped out the filter? If not, then I would run through another tank full or two and see if the mpg restores itself. There is no reason a new fuel filter would reduce gas mileage like that so I'm suspecting something else is at play here.
03-21-2010, 11:36 AM
I'm just guessing, but if the old one was clogged up, you could have higher fuel pressure with a clean filter. You would be using more fuel/running a little richer until the DME trims itself back eventually. Just a thought.
2003 Cayenne Turbo
03-21-2010, 11:54 AM
That's a good thought, but I don't think that's the case. The ECU makes hundreds of calculations per second and it wouldn't take very long to figure out the correct mixture. Also, depending on the year there would a return line so any unused fuel would go back to the tank anyway.
03-21-2010, 03:00 PM
Have you checked if there is a fuel leak around the filters snap on connectors. It doesn't need much of a weep while driving to blow out your fuel usage - remember it will only leak when the engine (or ignition) is on or running.
So to confirm a leak, you will have to get under the car with the ignition in the "on" position to pressure up the system.
2001 MV Agusta F4.
03-21-2010, 09:04 PM
Look for leaks as mentioned.
Disconnect battery for 10 min. to reboot the DME.
Most likely anecdotal, you cannot judge MPG based on one tank, run 5 or 6 and then avg. it out. Also, your baseline is likely skewed, esp. if based only on one tank, or even a few.
Cheers!
