Old 03-18-2010, 12:50 PM   #1
Royal purple XPR 10w40 question
Hi,
I'm almost due for my oil change and one of my friends friends... has Royal Purple XPR oil for sale, he'll give me 10qt for 100$ which is similar in price for regular PR or amsoil (I don't pay tax and shipping to this guy)
I have a couple of questions..
1. Is it good for my boxster? XPR is racing oil.. I don't race, my boxster is a daily driver to work and back
2. I'm worried about leaks.. car is 10 years old.. I have zero history of work done.. I'm worried that RMS could start leaking (I read that PR clean it out very well) I don't have 2k for RMS and clutch now I'd rather have sludge keeping it from leaking for time being
Should I get RP XPR? or should I just stick to M1 0w40 that is in the car now?
Sasha
sasha055 is offline   Reply With Quote
Old 03-18-2010, 01:57 PM   #2
While I recognize what I am about to say will start a debate: never the less, it needs to be said.
I would not use any product from this company. All of the various oils and gear oils we have looked at over the years (and we looked at a lot of their stuff) have been questionable at the minimum. Virgin oil analysis has demonstrated a significant lack of consistency in the unused products, indicating poor quality control in manufacture; UoA’s have demonstrated that their products shear down and fall out of grade way too quickly. Add in the fact that RP has regularly made claims and used questionable “legalese” concerning what ratings the products hold, and you have to begin to wonder what is going on. Probably the worst was when then claimed ACEA ratings, but got called out on it and eventually had to admit that they never submitted their products for ACEA mandated testing. Yet they continue to say their products are “recommended for ACEA applications”, whatever that is supposed to mean.
While we have not tested everything they make, the products we have looked at have not demonstrated the level of performance you would expect for the price they charge; and their ethics are questionable. You decide………
And I would not continue to use the Mobil 1 0W-40 either, but for different reasons that have already been beaten to death on this site as well as other oil oriented sites..............
Old 03-18-2010, 02:24 PM   #3
As JFP stated regarding the debate, oil issues have been beaten to death on this and other forums. I've used RP for years in my cars (mostly 911s), but for one reason or another, have switched to Castrol Syntec 10W40 for the last couple.
I will not use Mobil 1 or any other 0W40 product in my Box S...too thin.
You can usually find Castrol Syntec for under $5 on sale at AutoZone or comparable.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 03-18-2010, 02:43 PM   #4
I found the last ten quarts of Mobil 1 10 - 40 W high mileage formula, my car only has 30K but it was the best synthetic I could find in that range anywhere in the entire city. I figured the "high mileage" formula wouldn't hurt anything, hope that is right..
eightsandaces is offline   Reply With Quote
Old 03-18-2010, 03:16 PM   #5
Mobil 1 10W-40 is a much better product than their 0W-40, but you can still a lot better yet for less money.................
Old 03-18-2010, 03:30 PM   #6
Maybe with free shipping, the selection here was so weak I did look online! So apparently, until later in Spring, I can't do any better for the money.
Old 03-18-2010, 04:01 PM   #7
Go to your local Wal Mart, buy the 5 quart containers of Castrol Syntec 10W-40, a better oil and sells for about $23 per 5qt container, and no shipping............
Old 03-18-2010, 05:55 PM   #8
tonycarreon's Avatar
didn't use the XPR, but i did use RP.
can't say i found any reason to think it was worth the extra $$
Old 03-18-2010, 06:33 PM   #9
Rennzenn
j.fro's Avatar
Ditto on tonycarreon's experience. I've got the Castrol in my car now.
Old 03-19-2010, 05:54 AM   #10
pboxstercar
Guest
Posts: n/a
I don't like product bashing. Especially from highly suspect individuals.
http://www.performanceoilnews.com/oils_against_oils.shtml
"In the 0 up to 40 weight category, it seems Mobil's new 0W-40 produces terrific power, insignificant viscosity loss and a middle-to-fair wear particles rating."
Also just so you all know:
Zero-based viscosities, means naturally less friction. Less friction means MORE horespower.
Old 03-19-2010, 06:04 AM   #11
i sense an oil war starting...
- that article is 5 years old
- i can only state my experience
- others on this board have invested considering time and $ in their oil selections and i generally value their opinion
- if you like a particular oil, keep using it
Old 03-19-2010, 06:05 AM   #12
At the expense of greatly increased engine wear and tear...
JGM
2002 Boxster S
Old 03-19-2010, 06:21 AM   #13
07 Carrera S Cab
Boxtaboy's Avatar
Yeah!! According to that link, Mobil 1 makes the most hp!
Seriously though...I guess I'm gonna be the guinea pig here. I have been using Mobil 1 0W-40 on my car since the get go (it's an 01 base with 62k miles on the clock now), with oil changes between 12k-15k mile intervals or every two years (whichever comes first). Strictly by the book (according to the owner's manual). Let's see how long my engine lasts. Knock on wood.
So far, no engine issues whatsover except a broken water pump at 59k miles. I even threw in a bottle of Techron Concentrate about 1200 miles ago, and have not changed the oil yet because it's not time to change the oil according to my schedule.
FWIW, a friend of mine changed his oil (also M1 0W-40 exclusively), on his 2000S every 10k miles until he sold it (still running fine) at over 100k miles on the clock, for a 2006 987S. He also never experienced any engine problems whatsoever.
Old 03-19-2010, 06:26 AM   #14
landrovered's Avatar
This is not correct, wear occurs at startup with cold oil. Zero winter weight is supposed to be less viscous in colder temps, thus reducing friction.
Ten weight winter oil would by comparison have more viscosity which equals less flow, less flow equals more friction.
2001 Boxster S 3.6L, Zeintop
"Calling upon my years of experience, I froze at the controls." - Stirling Moss
landrovered is offline   Reply With Quote
Old 03-19-2010, 06:35 AM   #15
Hmmm... I only see viscosity loss results for 5 of the oils tested? Though they even mention, viscosity loss is not expected in such a short test.
An oil with "middle-to-fair wear particle rating" is one you'd choose, not good or excellent?
Also of note: AMSOIL is rated #1; coincidentally, the website is an authorized AMSOIL dealer!
Low viscosity oils are used for increased H.P. and fuel economy ( reduced friction ) , not for increased engine protection. The site states ( concerning 0 wt. oils ), "for regular street-driven engines, it would be better to look at an oil with a good service interval". Check the descriptions given by any supplier of racing oils, they call 20 wt. oils "qualifying oils", and recommend 30-50 wt. for longer races.
Steve
Old 03-19-2010, 06:52 AM   #16
pboxstercar
Guest
Posts: n/a
Bottom line:
The brand of oil chose is like which color is the most popular. All modern synthetic oils are good.
Old 03-19-2010, 07:04 AM   #17
I'd agree with that. But why use "good" if you can get "better" or "best"
Old 03-19-2010, 08:57 AM   #18
pboxstercar
Guest
Posts: n/a
Better or Best is ALWAYS subjective.
Old 03-19-2010, 09:53 AM   #19
I haven't used RP in my Porsche, but I have both the motor oil and gear oil in my Mazda right now. Kinda tough really to know how good an oil is unless you tear down the engine after 100K miles or have a lab and everybody claims their oil is 10X better than the next guys. All I can say is the gear box shifts smoother now and I recommend the gear oil for sure.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 03-19-2010, 10:09 AM   #20
When I first purchased my Boxster, the consencious was that Royal Purple was pretty good stuff, in fact my first oil change was to the Royal Purple 5w-40.
I kept on researching oils and once I learned about polyoester based oils I figured these are what I'm going to use. If your interested in POE (group 5) oils look into Red Line, or Motul 300v oils. Since we live relativly close to a Red Line source, Summit Racing, we went with Red Line.
In the end, it's your car, run the oil your confident in.
941MXVET is offline   Reply With Quote
