Old 02-20-2010, 10:05 AM   #1
Radio: No sound
After having replaced a dead battery and inserting the correct radio code, I can't seem to get any sound. All functions on radio seem to be working, just no sound.
('01 Boxster S) Anyone know a possible cause and/or solution? Thanks.
ston57 is offline   Reply With Quote
Old 02-20-2010, 10:22 AM   #2
Lil bastard's Avatar
Faceplate, HU contacts dirty or faceplate misaligned - all the function control is in the faceplate.
Pull faceplate, clean contacts w/ q-tip and alcohol, or pencil eraser if really corroded.
Carefully re-align faceplate contacts w/ HU contacts when reattaching it.
You should be good to go.
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 02-20-2010, 11:12 AM   #3
Thanks Lil, but wouldn't bad contacts affect the other functions also? All buttons work, stations change, and balance-bass-fader all seem to change. I'll try cleaning contacts though. Appreciate advice!!
Old 02-20-2010, 12:01 PM   #4
Not if the only dirty contact was the volume one.
Cheers!
1976 BMW 2002
1990 BMW 325is
Old 02-20-2010, 05:21 PM   #5
cleaned all contacts with ETOH, but no luck. Still no sound. Very puzzling. Any special procedure other than entering code to make it work?
Old 02-20-2010, 09:17 PM   #6
Not really. I assume you didn't hit the Mute button accidentally...??
Cheers!
1976 BMW 2002
1990 BMW 325is
Old 02-21-2010, 07:16 AM   #7
LOL! Thanks Lil, that's the first thing my wife asked me!!! Probably something very simple like that, but still can't figure it out.
Old 03-18-2013, 03:23 PM   #8
Smile Radio has no sound
This worked for me. Insert key in door lock. Lock and then unlock the door. Radio sound magically came on. Cheers
Rcomito is offline   Reply With Quote
Old 01-01-2015, 04:28 PM   #9
Dealing with exact same issue. Did you ever figure this out?
Thank you
Ferraridriver69 is offline   Reply With Quote
