-   -   How to check oil in Diffential (http://986forum.com/forums/boxster-general-discussions/22909-how-check-oil-diffential.html)
jcb986 11-28-2009 12:36 PM
I have a 2000 Boxster S with a small leak around my right output axle at the case, maybe. I want to check and add fluid and I assume it is going to be under the car. Just did the brakes when I saw the oil residue next to the inner boot. So, I what do I look for. JB :ah:
PS: Has anyone tackled this repair before so I know what to expect.
JFP in PA 11-29-2009 08:21 AM
Gear box and diff share the same oil, so check the gear box level.
Lil bastard 11-30-2009 09:28 AM
Manual or TipS?
The TipS does NOT share it's fluid with the diff/final drive, nor does it have a drain plug, though it has a fill. Pull the cover to drain - replace cover w/ new gasket and fill with gear lube, not ATF.
:cheers:
