Old 11-03-2009, 07:56 AM   #1
Send a message via Yahoo to 0Bosxter0
CEL Light
Has anyone heard of getting a CEL for a bad ground on an amplifier??
I recently got a P0650 fault and after some playing around im thinking it may be due to a bad ground from the amp?
Would that set of the CEL?
-Ben C.
0Bosxter0 is offline   Reply With Quote
Old 11-04-2009, 06:41 AM   #2
The P0650 is a generic code and is for any electrical open/short/grounding of the CEL. You may want to check your wiring.
Regards,
paul...
paulv is offline   Reply With Quote
Old 11-04-2009, 09:16 AM   #3
I re-ran the ground from behind the drivers seat to the front "boot"... everything seems to be working fine now..
-Ben C.
Old 02-05-2010, 05:47 PM   #4
Please help P0650 CEL
I am having the same problem. I have a OBD-II code p0650 and ceck engine light only works some time on my 00 Boxster S. Since I have witnessed the check engine light on, I don't think it is a light blub problem.
I also don't understand "I re-ran the ground from behind the drivers seat to the front "boot"... everything seems to be working fine now.."
Can some one please help, I just bought the can and I need it to pass emitions so I can register it.
zachem2 is offline   Reply With Quote
