Old 10-24-2009, 11:47 AM   #1
porsche986
Posts: n/a
drivers door wont open
hi the drivers door wont open, the window drops, inter light comes on but the door fails to open from the outside!
I have a boxster and also a 996 the problem is on the 996 but should be same as boxster?
any ideas?
p.s all started after I tested my alarm, then got in all fine, then again got in all fine, then closed my door and then wont open after I went to the chinese.??
Old 06-12-2010, 10:07 AM   #2
Same problem
Hello, I recently bought a 2003 Porsche Boxster S and the drivers side door has the same problem you discussed. Were you able to find what the problem was and a solution? Please help. Thanks
Trebor75 is offline   Reply With Quote
