Old 10-04-2009, 06:31 AM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
Just did an oil change and oil level is low already?
I just did an oil change maybe 500km ago and my oil indicator on the cluster came on with the last bar flashing. I checked the dip stick and it barely shows a oil reading. I used mobil 1 0-40 but I only put in 7 liters because the store only had that much. But still even with that I had a oil level reading at atleast 75% and barley a gas tank later I'm empty. What's going on? I park my car in the garage and never seen it drip oil...
violametallic-S- is offline   Reply With Quote
Old 10-04-2009, 06:46 AM   #2
Simple: You did not put in enough oil; the car needs 8.75 liters.........
Old 10-04-2009, 06:49 AM   #3
2001 RUF 3800S
Okay I understand but that still doesnt make sense. Where did the 7 liters go in one gas tank? Even if I put in 9 I still would have a low oil level reading..
Old 10-04-2009, 07:20 AM   #4
schnellman's Avatar
Oil Level Readings
Keep in mind that those marks on the meter represent very small amounts. And the oil went into the filter and other places it won't go with the engine not running. Just put in the rest of the oil the owner's manual calls for and all will be well with the world.
Old 10-04-2009, 08:46 AM   #5
2001 RUF 3800S
I put the rest in and all is well, I guess the meter is right at the top. Thanks
