Old 09-14-2009, 07:42 PM   #1
Schnell strut brace preload
I installed the brace today, but I'm not sure how much preload to use. I also can't get the bar to turn once it's been installed and torqued down... yes, the locknuts are loose. Any tips? Thanks!
http://ericfilcoff.com/pictures/986forum.jpg
2001 Boxster | 2007 Outback Sport
Need a freelance graphic designer?
Samson is offline   Reply With Quote
Old 09-14-2009, 08:50 PM   #2
I installed one recently too and had a similar problem. There's no good way to get that bar tight. Looks cool, but should have been hex bar instead of round so that we could get a wrench on it. Your best option may be to try to grab it with some channel locks and tighten it that way, but you risk marring your nice new bar. I just got mine good and hand tight and then locked it in place. I figure you can't put much preload on these any way. The brackets are kind flexy, so I don't think it's a big deal. Disconnect one side and push it up. You'll see how much the bracket on the other side can flex.
You're trying to preload it pushing OUT, right? At least that's how I would think you would want to load it, to help stop and inward deflection of the shock towers under heavy cornering with compression then being applied to the bar.
Kirk
Old 09-16-2009, 07:32 AM   #3
Lil bastard's Avatar
Try using a rubber strap wrench.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 09-16-2009, 02:09 PM   #4
Thanks for the replies... and yeah, a strap wrench. Duh.
